World water speed Records.
#42
I believe any speed record - any REAL speed record - needs to be done over a measured mile, so the speed needs to be sustained. Drag boats are cool, but the short speed bursts don't set world records.
The Speed Record for a propeller driven craft is still 225, owned by the Miss Budwieser Hydroplane. That's the mark that Bud Select, Gieco and Callan have been looking at.
#43
#44
i have to disagree with you,being involved in dragboats from the early 80's to late 90's i can promise you that a topfuel boat that holds a record is real. There are backup runs at a given % by the race organization such as with the IHBA these records are just s real as yours and i thank if you look even the APBA has some dragboat records.As for speed there is only one record that has been faster then a dragboat and Ken Warby holds it.We were running over 220 in 1983 we held the world record 5 different times in topfuel with a boat called Nitro Fever owned by Rick Hendrick yes the same one that owns NASCAR teams. The last record we set was at 229 with a back up run of 227. so the records you guys are trying to beat are real and so are the ones in the quarter mile just different types of boats
I'm sure IHBA keeps their own records that meet their rules. I was refering to the UIM record for a sustained speed over a measured one mile course, with the run being made in both directions and the speeds averaged.
I'm not taking anything away from drag boats and their mind bending speeds. It's just apples and oranges.
#45
#46
newsflash: Dateline Vienna 30 May 2007
At todays press confrence, the esteemed , if not infamous Horatio Scwartz was asked by a reporter from Popular Mechanics Magazine... "If the world speed record powerboat is powered solely by turbine thrust, with turbine thrust being mere air pressure and not a propellor, Mr Schwartz sir..would that not classify it as a 'BLOW BOAT'?
Before the great Baron Von Scwartz could answer, a fist fight broke out between the New Zealand Americas Cup Team and the BORAT members (Beak Owners Racing Advancement Team)
Stay tuned to you local AP wire affiliate for updates as more details are released about this sordid affair
#47
Drag boat records ARE REAL!!!! There is a DRAG BOAT team
that is prepairing to SMASH the prop driven one mile record!!!!Look for It to happen later this year!!!!!!!!!!!!!
TO BOLDLY GO WERE NO UNLINITED HYDRO CAN EVER GO!!!!!!!!!!!!!!!!!!!!!!!!
mpagliccia
Poker Runs and Boating Events
0
07-28-2008 03:34 PM
Strip Poker 388
08-06-2005 10:41 AM
