When to winterize question >
Old 10-04-2004 | 02:01 PM
Default When to winterize question
It's going to get down to 24 tonight but above 32 the rest of the nights. Mid 60's threw the day. Do you guys think it's alright for tonight???
32 thunder is offline
Old 10-04-2004 | 02:07 PM
fund razor's Avatar
Default Re: When to winterize question
24 is cold. If you are in the water, no biggie, but on land:
I would open my block drains and make sure that the passages aren't clogged with sand/mud/dirt. Other than that, I wouldn't think that you need to do the full winterization. If you have a power steering cooler loop I might unclamp on end and drain it out.
If you have fresh water, make sure that the lines are clear. Or, go ahead and add RTV if you use it.
fund razor is offline
Old 10-04-2004 | 02:12 PM
What about the liquid filled mph gauge?? How about hanging a light in the engine compartment I've heard of people doing that!!!
batty's Avatar
In or out of the water? 24 deg. i'd be kinda worried if its out if the waterI had my dads 34 sea ray out last year and the water lines in the cabin froze in one night( just the lines ) then it thawed the next day no leaks. I dont think I would chance it if its out of the water. if in the water you should be ok if its just one night.
batty is offline
Old 10-04-2004 | 02:13 PM
mopower's Avatar
Toxic FORMULA
If you're uncomfortable with the 24* tonight , throw a drop light with a 100 watt bulb in the engine compartment , unless the boat is left in the water. In that case the water temperature will keep the temp up inside as long as it's closed up and not extremely well ventilated
mopower is offline
Old 10-04-2004 | 02:40 PM
fund razor's Avatar
As easy as it is, I would still drain the water from the block.
A friend got burned by some compacted sand in a drain plug. Only took one good freeze. Pop. Crack above the drain on one side.
Damn water is strong. Some serious hydraulic pressure there.
I pulled my boat yesterday, and draining the block was the first thing that I did. I haven't even gotten the batts out yet.
Old 10-04-2004 | 02:51 PM
JUSTONCE's Avatar
I've had my boat out reaaallllly late in the season (december in cleveland) and I just put 2x150watt trouble light bulbs in the bilge and stuff rags in all the vents and exhaust. never broke anything yet.
JUSTONCE is offline
Old 10-04-2004 | 03:38 PM
baronmarine's Avatar
go with the ligth bulb, i'll be doing that tonight myself. i heard 29 tonite
baronmarine is offline
Old 10-04-2004 | 04:46 PM
tomtbone1993's Avatar
I would just move South that is way to cold for October
tomtbone1993 is offline
Old 10-04-2004 | 06:01 PM
Comanche3Six's Avatar
I winterized yesterday. It's Harley riding time in NJ!
Don't wait too long.
Comanche3Six is offline
boatnt
2
09-28-2006 08:04 AM
MILD THUNDER
10
11-26-2005 09:22 AM
Intolerant1
01-15-2003 10:29 PM
bcoffield
5
10-22-2002 10:46 AM
Sacandaga
19
09-16-2002 12:07 PM
