Winterization tool  "Check this out" >
Old 10-29-2004 | 10:37 PM
Comanche3Six's Avatar
Default Re: Winterization tool "Check this out"
Originally Posted by Pantera1
Cool but why even use antifreeze ?? Just get the water out , been doing it this way for years, never had a problem
When you drain a block dry it will rust internally
Comanche3Six is offline
Old 10-29-2004 | 10:43 PM
R Addiction's Avatar
AT Cult Member #3
This is true...fill that mill up with the good stuff!!
R Addiction is offline
Old 10-29-2004 | 10:58 PM
stevebaretta's Avatar
Charter Member #1015
awesome set up
Elvis was a boater too
stevebaretta is offline
Old 10-30-2004 | 01:30 AM
stecz20's Avatar
why dont you guys just run the antifreeze through your sea strainer. it will save you a lot of time... start up those doggies, and keep the strainer full of the good stuff. when you feel good about it, its done without the headache and all these rube goldberg contraptions.....
stecz20 is offline
Old 10-30-2004 | 05:33 AM
Interesting set-up. I do what stecz20 suggests after draining the block and exhaust.Three to four gallons through the sea strainer usually does it. With the Speedies, it simplifies things a little. Lots of good ideas out there. Go with what works best for you.
Lmarth is offline
Old 10-30-2004 | 11:14 AM
my32dominator's Avatar
1. I don't have sea strainers.
2. No headaches involved ....its a simple set-up.
my32dominator is offline
Old 10-30-2004 | 04:08 PM
offthefront's Avatar
What the hell is all that for ???????
offthefront is offline
Old 10-30-2004 | 04:52 PM
glassdave's Avatar
Neno the mind boggler
pretty cool setup, i think i may have to build somthing like that next year for sure. i like the idea of using the bilge pump and that yard cart thingie i just did the twins a few days ago. that looks alot easier than my way. keep in mind though guys that "green stuff" isnt to good for the environment when you fire'em up for the first time in the spring. the pink stuff offers all the same protection. not preach'n just somthing to keep in mind.
08 OPA High Points Champion
glassdave is offline
Harper220
12
12-05-2019 07:48 PM
electrical1
11
11-09-2006 08:51 AM
29KILROY
2
08-25-2005 12:59 PM
PhantomChaos
02-11-2003 03:38 PM
mikesufka
12-26-2002 11:23 AM
