-   -   where are the active thunder guys (https://www.offshoreonly.com/forums/general-boating-discussion/91400-where-active-thunder-guys.html)
KAAMA 12-01-2004 09:24 PM
Re: where are the active thunder guys
so if we built a 2005 32' give me 3 things you would change with yoour a/t. Make it outside the fiberglass which is from a mold and difficult to change. Specifically creature comforts, Gadgets or convenience items. And don't even touch the length of time it takes me to return phone calls.....
Pat, I'd like a new 2005 33' A/T with a 7.62mm 6-barreled Mini-gun mounted just outside the deck hatch nearest the bow please------and while you're at it I'll also take a mini depth charge launcher mounted off the swim platform and a 40mm grenade launcher mounted off the wind screen, and toss 15,000 thousands rounds of link-belt 7.62mm ammo with tracers, 1000 rounds of 40mm HE, a case of hand frags, and enough fuel and fueling arrangements to make it across the Atlantic and Indian Ocean to Iraq and up the Uphrates River. I'm going to take a little vacation to help my U.S. Marine Corps buddies in my old unit 3rd Battalion/1st Marines and I think an Active Thunder would be up for the mission! :D
KAAMA 12-02-2004 05:35 PM
1 Attachment(s)
Test...
ActiveThunder 12-02-2004 05:53 PM
if you get a chance I would like to see a picture. My problem would be my drive shaft and my third motor being in the way :rolleyes:
You simply put a transfer case in at the tailstock and then the pole would spin.
