oil change kits?
Old 12-15-2004 | 08:47 AM
mcollinstn's Avatar
Default Re: oil change kits?
Some guys don't realize that the Merc dipstick is designed to suck from it. While it does leave some leftover in the motor, the point I am trying to make is that you don't stick a teeny TUBE down the dipstick hole and try to suck from it. That'll take a month of Sundays. You screw a garden hose ONTO the TOP of the dipstick tube. Comes out much faster.
With that said, the drain plug hole is the BEST way to pull it out...
mcollinstn is offline
Old 12-15-2004 | 09:02 AM
Scott's Avatar
Charter Member #30
Exactly
BTW I'm not sure on this but I have heard that the standard drain plug adapters don't hold up well in a high performance (wave pounding application) It is better to install stronger through the pan or weld some type of fitting instead??????
I use a old 90degree spark plug boot over the top of the dipstick tube and hook it into the larger line on the electric change bucket.
I have Steps & Bubbles!
Scott is offline
Old 12-15-2004 | 10:07 AM
NJgr8ful's Avatar
Bingo ... that's why the top of the dip stick is 5/8 threaded PROS: Changing oil is soo fast and easy with the 5 gallon, as well as cheap, and clean, you can do it every 10-20hrs max anyway. CONS: Leaving a small amount, while changing very often will have no ill effects IMHO.
How about only changing filter every other when changing often (10-20hrs)??
NJgr8ful is offline
SkiDoc
23
12-22-2004 09:43 AM
mleslie951
27
11-08-2004 08:03 PM
sparky1
9
08-08-2004 09:30 PM
jeffg
2
08-24-2003 09:01 AM
jonesmarineinc
11-07-2002 06:52 AM
