HELP ! Need info on changing problem (freezing) fuel line on excursion . who has it ? >
Old 01-28-2005 | 11:42 AM
Default HELP ! Need info on changing problem (freezing) fuel line on excursion . who has it ?
I know they have a bad design on the fuel line for excursions . The low spot freezes . many of you talked about an upgrade for it availible from ford maybe ....... Someone help me out here . wasn't ford doing it for free ?
Thanks , Joe
boot is offline
Old 01-31-2005 | 08:44 AM
Default Re: HELP ! Need info on changing problem (freezing) fuel line on excursion . who has it ?
ttt ???
boot is offline
Old 01-31-2005 | 08:52 AM
GLH's Avatar
GLH
Diesel or Gas?
Our gas rig has never had that problem and a few weeks back we had a couple of nights at -30* and last winter all of January was below 0* and nothing of that nature happened.
You might want to be careful where you get your gas sounds like the problem is more moisture in your gas than the Excursion.
Ours is a V-10 gas rig.
GLH is offline
Old 01-31-2005 | 09:15 AM
Registered User
If it's a diesel, here's your place to find out any and every thing.
Run by and many members are Ford Diesel techs.
http://flatratetech.com/6literpowers...ultimatebb.cgi
Chris Sunkin is offline
Old 01-31-2005 | 01:38 PM
I'm sorry , It's a 7.3 diesel ...
Thanks .
boot is offline
Old 01-31-2005 | 02:48 PM
Boot, sounds like you got some bad fuel. Diesel (winter blend) should not have this issue until about 0 degrees or below F. Try some Techron (chevron) fuel system cleaner.
Wannabe
wannabe is offline
Old 01-31-2005 | 03:15 PM
LIOPA's Avatar
I own the V-10 gas and never had a problem .... down to 10 below zero....does sound like bad fuel in my opinion
LIOPA is offline
Old 01-31-2005 | 05:18 PM
Registered User
Thanks .
The best advice I ever got was to swap the 7.3 for the new 6.0. If Ford ever discontinues the truck, i'm going to buy six of them and warehouse them - enough to last the rest of my life.
Old 01-31-2005 | 06:36 PM
plumbers crack's Avatar
Talking Re: HELP ! Need info on changing problem (freezing) fuel line on excursion . who has it ?
The pickup in the fuel tank freezes and your SOL,you need to add anti gel to every tank of deisel.I know all too well,my deisel 7.3 box truck was towed 3 times last week.I also owned a 2003 dually 7.3 and same thing happened,I didnt cry when they stole it in canada,bought a 2004 with 6.0 and it never happened again.
plumbers crack is offline
Old 01-31-2005 | 07:38 PM
The "E" 350 vans have a fuel tank issue . The gaskets suck on the lines going into the tank . They have to be replaced and >GLUED< back in . I just had that too . Your tank has a drain plug . See how much water comes out ! We had a gallon and a half !
I'm not crazy ! I know there IS a fuel line update on the excursions because fuel sits in the low spot and freezes while driving . I just need to find this on paper to hand to Ford when we walk in the door and they say they never herd that .......
I'll bet it was Troutly that has this info . He finds all the dirt on Fords !
boot is offline
