need a Hull ID plate made
Old 02-03-2005 | 02:02 PM
magnum27's Avatar
Question need a Hull ID plate made
I was woundering if anyone new who I should get in touch with to have a hull I.D. plate made for the transom. I have the serial numbers on my title but the plate is missing on the boat and I would like to replace it. I thought about a trophy shop but figured what they use would not hold up after being exposed to salt water. Does anyone have any ideas?
magnum27 is offline
Old 02-03-2005 | 02:21 PM
JnT's Avatar
JnT
Default Re: need a Hull ID plate made
Not sure if this is what you are looking for but Office Depot does this kind of stuff. http://info.easiest.com/sre/officede...2511&CONFIGID= I need to get a new plate for mine since its cracked.
JnT is offline
Old 02-03-2005 | 02:23 PM
magnum27's Avatar
cool that will work just fine. thanks for the info
magnum27 is offline
Old 02-03-2005 | 02:33 PM
JnT's Avatar
JnT
Your Welcome.You should be able to make one online.
JnT is offline
Old 02-03-2005 | 02:42 PM
CROWN MAN's Avatar
I can make any kind of plate u need. What color is the hull? I have a brand new 60 watt laser engraver.
I can do dash plate also. etc: TEMP - VOLTS - RPM
let me no.
CROWN MAN is offline
Old 02-03-2005 | 02:53 PM
magnum27's Avatar
let me no.
It is solid black, when it comes to dash plates, do you use rocker switches and cuircut breakers?
magnum27 is offline
Old 02-03-2005 | 03:00 PM
let me no.
can you engrave powdercoat?
mike
SLINGSHOT is offline
Old 02-03-2005 | 03:03 PM
Stormrider's Avatar
JC Performance Engines
Crownman, can you cut and engrave 1/8" stainless steel?
Stormrider is offline
Old 02-03-2005 | 04:05 PM
CROWN MAN's Avatar
Mag email me the size and #`s I will do a couple and send them to u .
If they work,good If not We can try something else.
Maybe an old Peace of boat hull??? Engrave through the jell coat then epoxy it?
Old 02-03-2005 | 04:07 PM
CROWN MAN's Avatar
Storm I would need a 100 watt to gut any kind of steel.I didn't have the extra 25k on hand when I bought mine.
Anarchy Powerboats
09-04-2008 07:03 PM
sandcraft
03-29-2006 08:31 AM
knockoff
10-14-2005 08:18 AM
knockoff
4
10-07-2005 01:32 PM
BryanTuvell
Cigarette
4
03-04-2003 11:17 AM
