cigarette fuel tanks
Old 03-08-2005 | 08:01 PM
375stinger's Avatar
Default cigarette fuel tanks
when i was running my revolution for the first time monday i had to go fill up the tanks, and i filled up the two back tanks but realized they only held about 40-45 gallons each, and the boat supposedly holds 360 gallons of fuel total. Are these tanks jsut mainly used as auxiliary back up tanks?
thanks
garey
375stinger is offline
Old 03-09-2005 | 12:19 AM
Wasabe's Avatar
Question Re: cigarette fuel tanks
TTT
Wasabe is offline
Old 03-09-2005 | 12:48 AM
stecz20's Avatar
Default Re: cigarette fuel tanks
not to be a smart ass, i know nothing about revs.. are you sure they were fuel tanks...
stecz20 is offline
Old 03-09-2005 | 06:35 AM
cig1988's Avatar
Could it be your fuel gauges are off & thats all it took to top off?
cig1988 is offline
Old 03-09-2005 | 07:26 AM
Ed
Thumbs up Re: cigarette fuel tanks
If you have the usual oval shaped fuel tanks in the engine compartment, up against the hull sides...Then, yes...their capacity is in the range you stated. Typically, in a Cigarette, there will be four(4) separate oval fuel tanks in the engine bay. Two on the port, two on the starboard, divided by a full height, deck to hull bulkhead. Another fuel tank would be under the cockpit sole. These tanks generally all feed a main fuel manifold...and then feed each engine. Cigarette uses electric valves on the top of each rear oval tank to allow selection from the dash. Hope this helps, Ed
Ed is offline
Old 03-09-2005 | 07:14 PM
375stinger's Avatar
thanks ed. none of the gauges in the boat work, but the tanks were emptied while putting the new engines in because the boat had been sitting several years, and when i filled them up i found that both tanks could only hold about 40 gallons
cstobe
08-28-2008 08:46 AM
bigboat28
Pantera
4
08-04-2008 11:35 AM
SLINGSHOT
02-10-2005 07:32 AM
XCAV8
4
07-09-2002 10:35 AM
TomR
4
04-25-2002 08:50 PM
