Konrad Conversion
Old 03-14-2005 | 10:54 PM
Lofty's Avatar
Default Re: Konrad Conversion
Some of my ??? where regarding the fit of the TRS inner transome plate to the Konrad gimbal. I opted to not machine the exhaust port on the transom assembly as I have no silent choice. The concern I had was if the port on the TRS unit would bind against the Gimbal housing and prevent a good seal on the transom. I checked and measure but found that I could get the gap down to 2". The transom is 2.25" thick! No problem... But I still checked.
Attached Thumbnails Konrad Conversion-tn_gap1.jpg   Konrad Conversion-tn_gap2.jpg
Lofty is offline
Old 03-14-2005 | 10:56 PM
C_Spray's Avatar
Diamond Member #001
Fred Kiekhafer - Are you reading this?.....
C_Spray is offline
Old 03-14-2005 | 11:00 PM
Lofty's Avatar
Some more of the exhaust port.
Attached Thumbnails Konrad Conversion-tn_transmt1.jpg   Konrad Conversion-tn_transmt2.jpg
Lofty is offline
Old 03-14-2005 | 11:04 PM
Lofty's Avatar
So you may have noticed the wires back in post 12. Those are for the trim, which I'm not using because I have mechanical indicators. If you ARE using these then you need to either figure out how to get the out of your exhaust port or make sure to order your drives with the wires routed elsewhere. If you have the silent choice Konrad will have these come through in a different spot but you MUST tell them.
Lofty is offline
Old 03-14-2005 | 11:09 PM
Lofty's Avatar
OK so on to mounting these suckers! I greased the seal just like you're supposed to and then mounted the housing up. A dead-blow works well for getting it all the way up. If you don't knock it into place you'll have to pull it in with the studs. I wouldn't suggest doing that way as you could damage a stud or the casting if it binds.
Attached Thumbnails Konrad Conversion-tn_transmfit1.jpg   Konrad Conversion-tn_transmfit2.jpg   Konrad Conversion-tn_transmfit3.jpg
Lofty is offline
Old 03-14-2005 | 11:10 PM
Lofty's Avatar
I did take the oppertunity to buff out my transom. Don't pass this up, specially if you have an old red gel-coat boat like mine!!!
Lofty is offline
Old 03-14-2005 | 11:11 PM
Lofty's Avatar
ok.... I'm off to eat my steak before my Beagle gets it!
More later.
Lofty is offline
Old 03-14-2005 | 11:51 PM
Lofty's Avatar
You thought I was kidding?
Attached Thumbnails Konrad Conversion-tn_dinner2.jpg   Konrad Conversion-tn_dinner1.jpg
Lofty is offline
Old 03-14-2005 | 11:52 PM
Lofty's Avatar
and she goes in for the kill..........
Attached Thumbnails Konrad Conversion-tn_goinin1.jpg   Konrad Conversion-tn_forthekill.jpg
Lofty is offline
Old 03-15-2005 | 12:22 AM
Lofty's Avatar
Ok a few more from the inside then I'm off to bed.
Attached Thumbnails Konrad Conversion-tn_inner1.jpg   Konrad Conversion-tn_inner2.jpg   Konrad Conversion-tn_inner3.jpg
Lofty is offline
