water suction mystery,pressure is 0 again
I'm thinkin the small hose is collapsing or getting pinched. My block is new and no crud,,my gauge reads 30+ before I pulled the drive,then nothing for 6 months,,, and again 30+ after some fooling,,,I got a intermitant something , somewhere,,,,
Originally Posted by KYElimEagle
Cool, something I saw that bears checking out. It is the passage in the gimbal housing. I saw one that the plastic had collapsed into the passage and reduced the size dramatically. My mechanic says he sees this regularly. Can be checked out by removing the fitting on the gimbal. Are you sure your not getting enough flow? I had a water pressure guage that I had plumbed into the block, was totally unreliable due to getting plugged up.
the infamous bravo fever
Zanie
5
03-10-2005 10:58 AM
28Eliminator
11
06-22-2004 10:43 PM
