GGB Extreme Mufflers did the job!!! >
Old 04-20-2005 | 08:35 AM
GGB
Default Re: GGB Extreme Mufflers did the job!!!
Originally Posted by WETTE VETTE
Do you guys have your own decible meters or are you getting checked on a regular basis by law enforcement? What can be expected as far as power loss on a 600 CI NA motor running 6300 - 6500 RPM with the GGB's?
Craig
Criag,
What diameter and who's tailpipes are you running this through?
What kind of horsepower output are we talking?
Graham
GGB is offline
Old 04-20-2005 | 04:00 PM
Mudball's Avatar
I recently replaced my Corsa mufflers with GGB Extremes. These things work!! And they sound great!
I picked up 100rpm over the Corsa's.
One interesting thing is that the Extremes get more quiet the more water you push through them.
With my crossover, without a thermostat, I measured 84db.
With the thermostat installed and a pressure regulator, it now measures 89db. There is a huge difference in water flow between running the thermostat and not. Also, when the thermostat opens now, the mufflers get noticeably quieter, and measure 87db.
Interestingly, there is zero performance difference with differing amounts of water running through them.
I love em!!
Kent
Here's a pic of them installed.
Mudball is offline
Old 04-20-2005 | 09:31 PM
Mudball's Avatar
Do these flow?
Here's a pic. You tell me!!
And I do not work for Graham!! I'm just a happy customer.
Attached Thumbnails GGB Extreme Mufflers did the job!!!-ggb_thruoutside_small.jpg
Mudball is offline
Old 04-21-2005 | 12:04 PM
Lofty's Avatar
Graham,
Thanks for making up the long set for me. We're making up the spacers this week so I hope to have them mounted on Monday. I'll post up some pics when they're on.
These pipes look great and all reports so far are good. They are pretty beefy and don't have any "bits" that will burn out, blow out, etc. The noise Nazi's are out in force on the lakes here in Ca and are turning people away at the ramp so you guys are going to need to do something to quiet it down this year.
Lofty is offline
Old 04-21-2005 | 02:40 PM
Phantom1's Avatar
I'm interested too.
What could I expect on a set of dry CMI Big Tubes and about 675 HP?
Phantom1 is offline
Old 04-21-2005 | 03:03 PM
Lofty's Avatar
Phantom,
I've got great deals on GGB's if you're interested.
Lofty is offline
Old 04-21-2005 | 04:30 PM
GGB
Originally Posted by Mudball
Do these flow?
Kent,
What distance away from the boat are you getting those dB numbers at?
Graham
GGB is offline
Old 04-21-2005 | 04:35 PM
GGB
Originally Posted by Phantom1
I'm interested too.
Phantom,
You should come in anywhere from 88-90 dB(A) measured at idle 39" back and 39" up above the transom.
The best part - Zero power loss! Gauranteed!
Give one of our dealers a call to get the low down.
Graham
GGB is offline
Old 04-21-2005 | 04:50 PM
GGB
Originally Posted by Lofty
Graham,
No problem, show us some pics when you get them installed. As far as the noise nazi's go, no problem there either!
Graham
GGB is offline
Old 04-23-2005 | 08:05 AM
Attack's Avatar
Thumbs up Re: GGB Extreme Mufflers did the job!!!
I have the GGB clamp ons ... (750 Cobra's / Stellings) and they work awesome. I think it is important to route the water from the Stelling stinger out of the muffler. I took the flappers off the GGB's and placed a 4 inch extension tube on the stingers so that the exhaust is dry all the way to the end of the clamp-ons. I did not want any water bouncing back up the headers. Call me paranoid!!! The boat now sounds great and is quiet enough at the docks...
Attack is offline
