Bravo hinge pin tool
Does anyone know what size tool is needed for a bravo
hinge pin? I ordered all my bellows & swivel pin...
and a hinge pin tool. All showed for this weekends
project,except the hinge pin tool. Now Im screwed.
Any Ideas??
Any Ideas??
Originally Posted by US1 Fountain
Yep, used the 1/2" allen wrench many times on this. Don't for get to use locktite and torque it when reassembly.
allen somewhere.
Be careful if you use the allen. If it doesn't come easily, don't twist till it strips. The tool will do a better job than the allen if they are sticky. I stripped one with an allen, then got the others with the tool no problem. Then we used an easyout on the stripped one, but it was trashed at that point.
They are all over Amazon. Also, you may have to heat up the pins to get them out if they were installed correctly the last time. Might as well plan on putting a heli-coil or two in also. Use red loc-tite when installing the heli-coil too.
I have it out in my shop if I get a chance to find it before someone else posts the size.
https://formulaboatsforum.com/VBFORU...repaired.8597/
