Rusty block- how rusty is too rusty?? >
Old 04-18-2005 | 09:39 AM
mjb
Default Rusty block- how rusty is too rusty??
I would love some opinions from from those in the know.... I am rebuilding my gen 6 502's with all new parts and new heads. My blocks were very rusty. After the hot tank, I took them to the acid stripper to take them down to bare metal. After that, I could really see how bad they had corroded. The worst parts are along the sides under the deck surface and near the pan rails. Some of the corroded areas are even under the head gaskets along the sides.
The blocks have been decked, bored .030 over, magnafluxed, sonic tested and pressure tested. Everything passed the tests.
Blocks have been painted very well with epoxy primer and urethane topcoat.
Will the deep corrosion on the outside come back to haunt me? Do you think I will regret using these blocks 5 years from now??? THANKS
mjb is offline
Old 04-18-2005 | 10:33 AM
robyw1's Avatar
Default Re: Rusty block- how rusty is too rusty??
Got any pictures? 5 years? How long are you expecting these 502s to last?
Roby
robyw1 is offline
Old 04-18-2005 | 11:13 AM
Iggy's Avatar
I would think internal corrosion weakening the cylinders and such would be of more concern.
I guess if the block passed all the tests then it "should" be ok.
Maybe the block should have been coated with OSPHO, or some other chemical, to stop corrosion and seal the surface before repainting.
Iggy is offline
Old 04-18-2005 | 05:16 PM
Strip Poker 388's Avatar
Rob
Pictures ?
Atleast the gen 6 has the blind head bolt hole . I wasted the maching work on a gen 4 once when the head bolts pulled out on assembly Had to by a merlin block.
Strip Poker 388 is offline
Old 04-19-2005 | 08:51 AM
mjb
Thanks for the feedback...sorry, no pictures. I couldn't take the chance...not much of a gambler I guess so I ordered 2 new blocks yesterday...$$$ OUCH! whats another $3200 anyway...
mjb is offline
Old 04-19-2005 | 09:04 AM
Stormrider's Avatar
JC Performance Engines
Smart move.
$3200 for new blocks AND a piece of mind.
Stormrider is offline
Old 05-29-2005 | 10:29 PM
Rusty... if your looking to sell your rusty 502 blocks... shoot me an e-mail
[email protected]
Q
TeamPSI is offline
jdub
5
05-30-2007 08:31 PM
jdub
Drives and Lower Units
2
05-30-2007 08:26 PM
jmeng
11
04-18-2007 10:54 AM
cooltoys61
8
02-07-2005 12:04 PM
eliminator219
03-30-2003 05:11 PM
