Ignition recommendations needed
I just finished installing an M1 Procharger (non SC) on a 97 Baja Outlaw w/ 454 Mag (carb). I did my first test run Sunday and was quite impressed w/ the results. Spinning a 3 bl 27p Mirage Plus 5100rpm for an indicated speed on speedo (not GPS) of 80 mph. Last summer was running 64mph on speedo.
Anyway, I changed the plugs, installing A/C m43... . I'm would also like to freshen up the rest and am looking for recs.
What coil, wire set and plug gap do you guys recommend ?
Originally Posted by mopower
If you buy an MSD box...be sure to get two and be SURE to keep it on the boat. Buy only one and you'll find out why
My feelings also
Be sure to check out the Crane box.
It has an adjustable rev limiter (100rpm increments), and multiple advance curves.
These are potted too, so moisture can't get in em...
Originally Posted by samracer
go with an msd set up, thats all i can say, but i would do a .035 gap instead, with good plugs and an msd set up you will be fine with .035
Well, Fred, you should post the entire picture of the motors that you trust the Crane box to!!
That is a setup to dream about (in my WILDEST dreams!)! I love your bracket for the electrical items. Extremely clean.
