Drive alignment problem >
Old 04-27-2005 | 11:51 AM
hillbilly24's Avatar
Default Re: Drive alignment problem
Originally Posted by sutphen30
are you positive you put the spring and fiber washer back in or missing one or the other.i'm suspect that this has happened or are the holes for the transom f-ed up,,gimble should have gone back in the same place.alignment changing,,maybe i'm just real lucky but i've done this and alignment was still good.just thinking out loud.
btw,,nice job monstaa,,looks awesome.
Sometimes you get lucky and things will be right on after new installs but sometimes things get a little wacky on you. Monstaa's method is the best available for the situation but is a little more involved then what I spoke of. If you have the Money and time go for it.
hillbilly24 is offline
Old 04-27-2005 | 08:20 PM
monstaaa's Avatar
Originally Posted by Feelin Nauti
Nice looking setup monstaaa. I like the idea of using the top of the stringer for extra support.
t.y . it is deffinitely the way to go. sometime's the gimbal bearing can use a little messaging, as far as pivoting. have experienced this numerous times. either way good luck.
monstaaa is offline
MariahMadness
7
02-28-2006 05:18 AM
Andy
2
10-03-2004 05:33 PM
Krumbsnatcher
4
09-09-2003 08:18 AM
25 Eagle
1
02-23-2003 09:47 PM
cheitman
17
02-20-2003 06:06 AM
