How accurate are GAFFRIG SPEEDO'S
This may be a stupid question but how accurate have you found Gaffrig speedometers to be? Some people have told me they are pretty close to there GPS readings. I was just trying to see what others have found.
Re: How accurate are GAFFRIG SPEEDO'S
Mine is right on up to about 50, then it gains a couple by top end, mid 70's.
Speedos are nothing but a pressure gauge. The quality supply of water, or lack of, to the pick up will have major effect to the accuracy of the gauge. |
they are pretty accurate in the mid range but not at slow speed ot top end. If you plan on doing any bragging you better have a GPS speed and preferbaly a picture using the tattle tale :D
Mine is good to 90 then the pickup is out of the water.
Now as far as the other gages . fuel pres,oil pres. there off :( |
My water pressure speedo (Eliminator gauge) which I believe is Gaffrig, never worked worth a dam on the Daytona. I think with the high X dimension that the pick-up on the drive is getting too much air to be the least bit accurate. It always read about 25-30 mph slow...
US1 Fountain said it right about the quality of water supply to the pick-up. |
In addition, I recently installed a Livorsi GPS speedo and took away all the guesswork, not to mention plugged pick-ups...
On my Bullet, the speedo is dead on until 60 mph, then it exagerate's like it's been drinking all day!!! About 4 mph over gps readings at top end.
My boat only goes about 60mph this year that is,after I get a 500 in it ,it should kick ass!!! So maybe it is accurate? I will have my gps installed this weekend.
My speedo reads 80 at gps speed 73. I love it :D
spot on at 50. I just keep the gps speed readout in a small corner of my Garmin. Very useful for finding optimum trim setting. Content to let my passengers believe the Speedo guage :evilb: |
| All times are GMT -5. The time now is 12:32 PM. |
