Which First - Full Hyd or Tabs??? >
Old 05-06-2005 | 06:35 PM
GPM
Default Re: Which First - Full Hyd or Tabs???
Originally Posted by LHC30Victory
GPM - I take it that the drives wander because the motors are on? they don't have any play in them (from the outside) on the trailer.
I am thinking that I would use the steering all the time and the tabs much less, so go with the steering and keep the speed down if it doesn't fix it until tabs arrive.
The drive had no play when sitting on the trailer with the motor not running. The drive didn't move when the motor was running,sitting on the trailer. Unless you would push on one side or the other then it would take off. I blamed it on the Brazil valve, I tried it after I changed to full hydraulic steering and it would not do it. I don't run tabs, never did.
GPM is offline
Old 05-06-2005 | 07:24 PM
Dave M's Avatar
Veteran: Navy
I'd get the tabs first, especially if you run in rough water.
Dave M is offline
Old 05-06-2005 | 08:01 PM
Stormrider's Avatar
JC Performance Engines
Originally Posted by Too Old
My vote would be for tabs.
Like a set of these puppies.
Stormrider is offline
Old 05-06-2005 | 09:22 PM
OK so as of now it's 4 to 1 for tabs.
THanks for all of your input, please keep it coming.
As far as tabs go, the 280 K-planes are expensive and only 19" long, Dana HP1000T are 21" and less expensive but seem to be of very good quality and reputation, Dont know much about Trick stuff - any input vs Dana? I plan to go with Mech indicators so Livorsi gets my nod.....Am I missing anything?
From the Pic of the Trick Tabs, it seems that the indicator cable is through the mount plate rather than a seperate fitting. Good/Bad on that issue????
LHC30Victory is offline
Old 05-07-2005 | 03:33 AM
Dave M's Avatar
Veteran: Navy
That's the way the 280's are too.
Dave M is offline
Old 05-07-2005 | 01:00 PM
Stormrider's Avatar
Call fred, aka Too Old, of Trick Marine.
He's got the dope on all the goods!
Old 05-07-2005 | 07:10 PM
onesickpantera's Avatar
I don't like the "add-on" external steering. It's nothing more than a band-aid system. I would go with full hydraulic steering first and then, if you need the tabs, get them.
onesickpantera is offline
Old 05-07-2005 | 08:37 PM
GPM
Well put!
GPM is offline
Old 05-08-2005 | 02:40 AM
articfriends's Avatar
My 27 ft v did what gpm describes to a tee,even with external hyd,but 95 % of it went away after going full to the helm.I would favor the tabs over full hyd only if you said your boat porpoised or listed to one side from torque twist . My boat would do it(chinewalking) above 75 mph once you were no longer accelerating,i extended the tabs and it really made no difference,the full hyd fixed it,Smitty
articfriends is offline
Old 05-08-2005 | 10:22 PM
Thanks all for the insightful comments. I will go with the steering first (its easier to put on) and let y'all know how things shake out.
robo
Do It Yourself, Boating on a Budget
2
01-25-2008 11:06 AM
boatguy94
8
04-17-2007 07:15 PM
Rage
14
10-10-2005 11:20 AM
johnnyboatman
2
07-18-2004 07:51 PM
Nordicflame
6
12-18-2003 09:56 PM
