Bravo One oil leak- Help! >
Old 05-10-2005 | 04:42 PM
Mr Gadgets's Avatar
Charter Member #601
Default Re: Bravo One oil leak- Help!
DR,
It is a regualar 3/8" coarse thread. I use a 3/8" bolt with the head cut off with a hole drilled thru it to fill it.
Mr Gadgets is offline
Old 05-10-2005 | 09:24 PM
rbtnt's Avatar
I took the fitting and hose off my hand pump, put a barb fitting on the hose, screwed fitting into a valve with a gauge, put an quick disconnect on the other side of the valve to connect to the air compressor.
Don't go over 10 psi!!!!
rbtnt is offline
Old 05-11-2005 | 09:56 PM
I bought a 7 dollar oil pump thing from west marine and hooked it up to a hand tire pump......cheap and easy
happy hours is offline
TROUBLE MAKER
Drives and Lower Units
26
07-04-2020 02:04 PM
mez
2
04-28-2007 10:45 PM
HiPerf2000
4
06-17-2004 02:19 PM
RUSSSR1
12
03-17-2004 08:32 AM
Ran-Dom 32
4
07-08-2003 09:26 AM
