Replacing K-plane indicator cable ? >
Old 05-09-2005 | 02:23 PM
HiPerf2000's Avatar
Default Replacing K-plane indicator cable ?
I ordered the correct cable and it should be here on Wed. It is the longer cable (port side). It broke outside the boat at the tab.
Are there any tricks to installing this? What are the chances of being able to duct tape the ends together at the transom, and pulling the old one out from behind the dash...and having the new one rig itself into place????
Also, i thought i heard the conection to the indicator is spring loaded somehow ?
HiPerf2000 is offline
Old 05-09-2005 | 02:36 PM
t500hps's Avatar
21 and 42 footers
Default Re: Replacing K-plane indicator cable ?
I have the exact same problem. My cable works, but isn't looking too good. Where/ how much was the cable? Mine is red and cracked at the transom. My Starboard engine is out right now so replacing it would be much easier in the next week or 2. Anybody know the answer to this????
t500hps is offline
Old 05-09-2005 | 03:35 PM
HiPerf2000's Avatar
Your cable will have a number on it. something like this.....
032377-003-288 where the "288" is the length in INCHES. I ordered mine from here. Was the cheapest place i found it ($36.00 for a 24ft cable).
http://www.go2marine.com/g2m/action/...tegoryId/11570
Old 05-09-2005 | 03:54 PM
CIG3's Avatar
for pull the new cable, you can use the tape method but sometimes it does not work. They make a coupling that connects the new and old cable to put it thru. Should be available at west marine
CIG3 is offline
Old 05-09-2005 | 07:00 PM
MrCIG's Avatar
Charter Member#330
Just did mine a couple weeks ago I duct taped them together and used some petrolium jelly and lubricated the out side to make it eaiser to slide by the rest of the cables in the tube.
Worked just fine
Mark
MrCIG is offline
Old 05-09-2005 | 08:07 PM
Cignificant's Avatar
Worked just fine
Mark
Ditto, but I used good old grease. Russ, call Formula, they should be able to tell you the exact length.
Steve Gresham
'03 Donzi 33ZX
Cignificant is offline
Old 05-10-2005 | 03:52 AM
cig1988's Avatar
When your into the indicator end up by the dash...do yourself a favor and lay a big towell under everything. They are spring loaded & can be a pain in the azz. You may want to order an extra couple of pointers & springs. Just in case.
cig1988 is offline
Old 05-10-2005 | 07:39 AM
HiPerf2000's Avatar
Thanks for the info guys.
RJBBC
9
05-04-2008 06:43 AM
shawn
9
04-30-2008 08:15 PM
mjb
Cigarette
27
08-13-2007 08:45 AM
awsomethunder
Drives and Lower Units
9
04-30-2007 08:52 AM
Sydwayz
17
08-14-2006 10:08 PM
