STARTER HELP, look at this! >
Old 05-17-2005 | 10:45 PM
hillbilly24's Avatar
Default Re: STARTER HELP, look at this!
Originally Posted by 1BIGJIM
I installed the starter today. No shims bolted right up, if I did not see it with my own eyes I would not believe it.
To bad it sounds like a Honda starting, before the Big Block roars to life
Iv'e installed about 100 of those things at the shop, no problems and have never needed a shim for one. No need for the support bracket cuase they don't weigh 50 pounds anymore. They are also a hell of alot easier to install on twin applications on the port engine.
hillbilly24 is offline
Old 05-17-2005 | 10:50 PM
Prowler's Avatar
Charter Member #1472
the nice thing about the small is lighter weight,for starting the bolts in,most of the time it would be nice to have the smaller one,cause they ain't never out in the open,tight quarter's.
Prowler is offline
Old 05-18-2005 | 07:41 AM
Airpacker's Avatar
The small starter uses a planetary gear reduction transmission inside to increase torque output. The are plenty powerful little buggers. You willl find the same starter under your GM trucks.
Airpacker is offline
Old 05-18-2005 | 07:51 AM
The Menace's Avatar
There is even a smaller one out on the market now. They were installing one on a Chevelle on HORSEPOWER TV last weekend.
The Menace is offline
nordic95
6
06-06-2010 11:29 PM
dyno
36
09-07-2006 09:00 PM
dyno
7
06-26-2004 12:16 AM
blue thunder
16
01-17-2002 09:45 AM
