Hyd. roller set up. >
Hyd. roller set up.
Hyd. roller set up.
Old 05-17-2005 | 08:28 AM
Question Hyd. roller set up.
Okay you engine gurus. What spring and spring pressure would you run? T& d shaft rockers, 7/16 pushrods, Canfield Heads, Comp cams 242 248 @ .050, 612 637 lift, 110 int. c/l, 112 lobe sep. ( 565 cu. in.) What rpm do you think the Comp. Cams hyd. rollers would go into valve float w/ piston to valve issues.The engine has about 9.2 comp.w/ one small intake valve relief on a flat J E piston. Also where would you set rev limiter?. 38 cig.general performance use. I am moving away from solid rollers and want to stop wrenching so much! Ultimatley I would like the valve train to live as long as the rings and bearings. Thank you in advance. Dave
nightmoves is offline
Old 05-17-2005 | 09:38 AM
RLW
Default Re: Hyd. roller set up.
PM Rmbuilder for this information.
RLW is offline
Old 05-17-2005 | 11:21 AM
You may want to try some of Morels HLT hyd. They only have .030" hyd movement, you set like a solid at Zero lash and can run 200# seat pressure on them.
If you haven't bought the cam, I would rethink that stick to.
Chris
cstraub is offline
Old 05-17-2005 | 04:57 PM
That combo is good for ~650hp....pretty sure that comp stick will run to 6000 rpm with ~160# on the seat, but as cstraub said, those morels and a bit more pressure would ensure you stay away from valve float, and like he said... a bit more cam too
RichardCranium572 is offline
Ken N
4
03-09-2008 09:20 AM
88Fount33
3
02-22-2008 10:01 PM
lukiepal
4
04-03-2005 09:19 PM
paradigm shift
12
08-01-2003 10:30 PM
Elite Marine
6
08-29-2002 10:04 PM
