Re: help...blower surge
As persistence over comes Resistance here are the results
Starboard motor Runs fine, fuel pressure was low at 35 at idle.... I cranked it to 42 psi still runs great. Vacuum is 11 pounds Port motor still runs the same. Fuel pressure was 42 at 1300 rpm as thats the only place I can get it to run without surging. The full pressure also stayed constant up to 4000 rpm. Vacuum is at the 10 to 11 mark. I reinstalled the the fittings and vacuum line to the regulator as well as to the gauge thinking maybe that was the leak.... no difference. Although when I pulled the vacuum line from the regulator the surging got worse. So... now I'm at a loss... |
I used a Merc scan tool and this is what I got...???
PORT Engine RPM 850-1400 Coolant Temp 85 Manifold Air Temp 92 TPS Volts .50 Trottle tps 0 Map Volts .72 Manifold Pressure 7 Baro Volts 2.09 Battery Volts 14.1 Spark Advance 3.1 deg IAC position 41 Base IAC 21 IAC follower 20 Injector on time 2.7 Fuel flow rate 5.5 2nd run for port engine Engine RPM 1400 Coolant Temp 115 Manifold Air Temp 107 TPS Volts .50 Trottle tps 0 Map Volts .70 Manifold Pressure 6.9 Baro Volts 2.09 Battery Volts 14 Spark Advance 9.8 deg IAC position 77 Base IAC 77 IAC follower 0 Injector on time 2.8 Fuel flow rate 7 STARBOARD Engine RPM 830 Idle speed 837 Coolant Temp 81 Manifold Air Temp 70 TPS Volts .52 Trottle tps 0 Map Volts 1.01 Manifold Pressure 8.5 Baro Volts 2.09 Battery Volts 14.2 Spark Advance -.03 (all over the board) IAC Position 9 Base IAC 9 IAC follower 0 Injector on time 2.4 Fuel flow rate 3.3 I took both throttle bodies off and adjusted the port side to match the starboard side and then swapped them. I swapped one peice at a time and then ran the motors. The starboard motor runs fine and it has all the port sensors, ECU, MAP, IAC, TPS, and trottle body, yet I still have a surge problem. I'm at a loss??? |
Originally Posted by Stingray69
Is the ignition system fresh?
[QUOTE=JLANE]I used a Merc scan tool and this is what I got...???
PORT Engine RPM 850-1400 IAC position 41 Base IAC 21 IAC follower 20 2nd run for port engine Engine RPM 1400 IAC position 77 Base IAC 77 IAC follower 0 STARBOARD Engine RPM 830 IAC Position 9 Base IAC 9 IAC follower 0 QUOTE] I noticed your IAC (idle air control) readings, they're all over. Is the motor making a loud air sucking sound at idle? |
You may have a bad IAC and the motor is compesating by dumping extra fuel?
Someone mentioned that surge is from a lean condition? I always thought it was a rich condition from fuel puddling in the intake.... |
Someone mentioned that surge is from a lean condition? I always thought it was a rich condition from fuel puddling in the intake.... I agree but I swapped throttle bodies and the starboard engine ran fine. The port engine has all the starboard sensors and it still surges. |
I always understood that the surge was caused by uneven fuel feed. My idles were adjusted up to approx 11-1200 and surge when first fired up. Aftyer running a minute they calm down to a low surge if any at all.
Try swapping the ECM from one motor to another. You have the benefit of two motors, so swap away.
Anyway.... I really appreciate everyones input I'm sure will figure it out soon. Jason |
Your surge is caused by an over-rich condition. You verified that yourself when you pulled the vacuum line from your fuel pressure regulator and the condition worsened. IF the calibration is correct and this surging was not present before, and since you have swapped all the sensors and ecu.... I'd have your injectors cleaned and flowed, sounds like you got one that is leaking.
| All times are GMT -5. The time now is 05:01 AM. |
