Why higher oil pressure >
Old 05-25-2005 | 11:47 PM
Default Why higher oil pressure
I have a Gen iv 502 Carb that was stock running 40-50 lbs
oil press. I changed the cam lifters valve springs and added roller rockers, all crane matched. new cam 530/550 lift
226/236 dur. The oil pressure is now 60 lbs @ 700 rpm's
and 70 lbs @ 2000 rpm's. Crane tech line thought it could be a
restriction at the roller rocker push rod and oil hole not lining
up correctly. I have changed rockers back to stamped steel
and have the same high pressure.
warlockgy is offline
Old 05-26-2005 | 09:14 AM
Smitty's Avatar
Default Re: Why higher oil pressure
Is it possible that the new cam is a little tighter and thus causing a higher reading ?? Also depends on where you are taking the reading from.
Smitty is offline
Old 05-26-2005 | 10:00 AM
Reading at sending unit port above oil filter pad. boat
guage and mech. gage read same. I think 60-70 lbs.
is to high,will be hard on cam gear and dist. gear .
Old 05-26-2005 | 11:31 PM
Has this happened to anybody. Do you think this pressure
will cause damage to main bearings or dist./cam gears.
Viper TT
9
07-24-2007 08:02 AM
JasonSmith
1
02-18-2007 03:17 PM
38SprtCruzKev
2
08-13-2004 12:43 PM
jeffg
2
08-24-2003 09:01 AM
