"To Change Or Not To Change....." >
Old 06-02-2005 | 05:06 PM
Angry "To Change Or Not To Change....."
After yanking my boat back from the mechanics who never could fix my cold start issue (502 MPI-- I know it is related to the IAC-- I'll fix it myself!!), I launched, and got up to cruise across the lake only to have the hi-temp alarm go off and see over 200 degrees or more on the gage! Evaluation proved they forgot to install a hose clamp on the power steering cooler output hose-- it blew off and nada cooling water. My question is-- I had just 2 weeks before filled the engine with $35 worth of 15/50 Mobile 1 Extended oil. Should I drain and refill with fresh? Engine seems ok-- runs strong, no noise-- after *****ing to the mechanic, he said the hi-temp alarm sounds at 185 degrees so the oil and engine should be safe. There was no steam or knocking-- what would you do? At about what temp does Mobil 1 deteriorate and what temp does an engine break? Why can't this stuff happen at the END of summer?????
norton is offline
Old 06-03-2005 | 09:10 AM
Default Re: "To Change Or Not To Change....."
Your oil is probably ok but I would change it. I would never risk thousand$ over a $35 oil change
Dangerous Dave is offline
BajaRunner
4
03-02-2006 06:23 PM
TalkOffshore
04-25-2004 09:10 AM
Formula Outlaw
02-19-2004 08:26 PM
Tejas Raz
2
06-26-2003 09:53 AM
mikesufka
12-26-2002 11:23 AM
