External Belt Driven Fuel Pumps,    why is it...................???? >
Old 06-04-2005 | 08:47 AM
cougarman's Avatar
Default External Belt Driven Fuel Pumps, why is it...................????
Friend of mine asked me to post a question for those in the know.
588 ci drysumps with belt driven Fuel pumps.
Question is once the pumps are primed and you run the boat
week to week everything is great. If you run it every second week it's fine also.
How ever if you wait 3 weeks the fuel drains all the from the
carbs back to the tank. And then the whole system needs
to be primed again. More times than not it's not an issue
using a cordless drill. His concern is if it ever loses prime
on the water, then it would be a (B) to get it reprimed.
So Is this common with the Belt driven pumps?
Or is there something failing or missing that needs to
be taken care of?
Thanks in advanced for all your help.
Cougarman
cougarman is offline
Old 06-04-2005 | 02:16 PM
Strip Poker 388's Avatar
Rob
Default Re: External Belt Driven Fuel Pumps, why is it...................????
not sure on the belt driven pumps,
I just ordered a ck valve from areomotive #10 It was about 62.00. That is supose to stop this? Earls and XRP makes them also.Mine get worse when the gas tank is low on fuel.
Strip Poker 388 is offline
Old 06-14-2005 | 08:58 AM
cougarman's Avatar
Recieved Kinslers Fuel Systems, check valves, Nice Stuff!
Built real well, they have an internal metal flapper,
much like an exhaust system. open supper easy and seal
real well.
They are installed and work great, also improved the initial cold start up. Used to die atleast once, now that there's fuel there it
just keeps running upon the turn of the key.
Thanks to all
Cougarman
tewks
0
10-03-2005 08:24 AM
dyno
9
11-10-2004 05:05 AM
David Haag
5
05-05-2004 11:44 PM
Monty
1
10-21-2003 08:23 AM
WETTE VETTE
4
06-13-2002 01:49 PM
