Piston oilers >
Piston oilers
Piston oilers
Old 02-10-2009 | 01:47 PM
IRONMAN's Avatar
Has anyone tried running the oil up the inside of the rod? Seems like you could use less oil that way.
IRONMAN is offline
Old 02-10-2009 | 03:27 PM
"Pin oilers" are good for getting oil to the wrist pins, but wouldn't be much help in cooling the pistons.
Additional question, does anyone run piston oilers in a NA application?
BenPerfected is offline
Old 02-10-2009 | 06:52 PM
CcanDo's Avatar
14 apache,You can verify with BLP,I would suggest .040...then coated pistons (ceramic domes and teflon skirts) and DLC pins...Lube Tube rods may be worth considering also...Pulling just that much more heat out...A four gallon oil tank is another cooler/deaireator.
Ben,with your vacuum, .040 should work fine...Verify with BLP....add volume to the pump ...I have the BLP fixtures you can borrow.
CcanDo is offline
Old 02-10-2009 | 09:24 PM
14 apache's Avatar
Thanks for the help, Eric
14 apache is offline
Old 03-18-2015 | 10:15 AM
14 apache's Avatar
ttt
Old 03-18-2015 | 10:43 AM
Good info, does anyone have a blp jig I could borrow or rent?
Unlimited jd is offline
Old 03-18-2015 | 03:53 PM
You are welcome to mine after I take it out of the box (had it 2 months) and use it. Probably be two weeks til I get 2 it. If you don't find one between now and then I have you covered.
Black Baja is offline
Rrice
Wanted
4
07-13-2008 11:41 AM
Quest for Speed
3
02-16-2003 08:39 PM
Troubled 26
02-28-2002 10:44 AM
Troubled 26
0
02-27-2002 12:30 AM
