Bravo to X
Old 06-12-2005 | 02:41 PM
Registered User
Default Bravo to X
I just found a good deal on a couple of X drives ,thinking of changing out my 1990 bravo's since one is already blown. Anyway I was wondering if the X drive has the larger U-joints like the XR that would require changing Gimbal bearings or if it is a direct swap for a standard bravo? Thanks.
320es is offline
Old 06-12-2005 | 03:36 PM
ali
Default Re: Bravo to X
My findings so far have been that all pre OW x/xz drives have the larger u-joints, but none of the new OW x series have come with the larger just standard size bravo u-joints.Zip None of the b1's or b3's.
ali is offline
Old 06-12-2005 | 07:28 PM
FOUNTAINATLAST's Avatar
Its probably not a bad time to change your bearings anyway, being a 1990 they've got some age. Just a maintance precaution, there fairly easy to change, just my 02.
FOUNTAINATLAST is offline
Old 06-13-2005 | 04:04 PM
Registered User
I agree but they have both been changed recently. One was changed right before I bought the boatand the second one I already replaced when the drive blew. I replaced it with the one for a standard bravo. Don't you have to replace the bellows as well...if I do need to change the bearing to the larger style?
320es is offline
Dave1972
6
03-30-2009 04:06 PM
1BIGJIM
Drives and Lower Units
3
06-10-2008 12:46 PM
PARADOX
0
02-27-2008 02:31 PM
articfriends
1
07-30-2006 08:10 PM
rslick
13
06-15-2005 11:54 PM
