How Much HP?? >
How Much HP??
How Much HP??
Old 06-14-2005 | 08:07 AM
Angry Re: How Much HP??
Originally Posted by sutphen30
you got to be kidding,,, at what rpm were you spinning when it let go??
and no,,wish i did.
5200.
The builder said no no way the old motors (Stock HP 500's with Whipples) made more, but Speed and RPM's indicated different.
When I told him about the motor puking he asked if I changed the timing.
Go Big is offline
Old 06-14-2005 | 02:54 PM
Default Re: How Much HP??
9.1 CR and 10 pounds of boost, what octane fuel did you use?
shawn is offline
Old 06-14-2005 | 03:44 PM
92 with 28deg Timing.
Go Big is offline
Anyone have any experience with SCAT crank and Rods.
Go Big is offline
Old 06-14-2005 | 04:02 PM
Scat parts are made in china ....
is that what was in the motor ???
was this a world crate 540 ??
Don
chromecat is offline
Old 06-14-2005 | 06:06 PM
Don
No, it started life as a HP500, then was stroked to a 540 with Scat. GenVI block.
Go Big is offline
Old 06-15-2005 | 05:21 PM
articfriends's Avatar
Originally Posted by Go Big
5200.
Boy this sounds painfully familar,my 27 ft baja went 79 mph w/502 w/minor upgrades,procharger,merlin heads ,built 540 using same top end and bigger cam expecting decent gain ,made what i considered sub par hp on dyno(629),dyno operator swore the numbers i made were better than my 502 would have made,BOAT WENT 76MPH!!!!It took 3 months of tuning in boat to get speed back and the a additional 6 mph gain. This time around i researched things MUCH better,motor now makes 944hp,962ft lbs tq. Do you know what your intake to exhaust ratio is?The merlin heads i was using had crappy I/E of 60-62%,your blower will push air good thru a stock or mediocre intake port BUT if your exhaust port flow isn't there you will have hard time making any real power,Smitty
articfriends is offline
Old 06-15-2005 | 05:29 PM
Another thing to consider,at least in my case,was 502 was 8.75 base compression and 540 i built was 8-1 base compression. The cubic inches alone should give you 7.5% more power but i have read that the biggest power gains from compression changes are when you go from 8-1 to 9-1 so if you gained 7.5% from just the cubic inches but built real 8-1 blower motors you might have gave up 8-10 % from compresion drop. The good news is if yuo were running 10 psi boost before at 8.75 or 9-1 w/your 502"s you should be able to go up a couple lbs boost on same gas in your 540's at 8-1and see a decent gain,Smitty
Old 06-15-2005 | 05:35 PM
I just re-read your post,are you sure its 9-1? did pistons have flat tops or dish?my 540 pistons were J/E racing(not srp's) specifically for blower app and they have dish as pictured,Smitty
Old 06-15-2005 | 06:21 PM
I am not sure exactly what the pistons are, the specs I was given was that they are supposed to be 9.1:1. I will know more when they are yanked and I inspect them.
Does anyone know what the Stock HP 500 Carb compresion is?
I may have a solution. I will keep everyone informed as it unfolds.
Go Big is offline
