More carb questions???? >
Old 07-03-2005 | 01:15 PM
kmiller's Avatar
Default Re: More carb questions????
Still going at it!! I got a small amount of gas from the vacuum line when I removed the gage is that normal??? Also I bought this used so I have no manual / I see that it has a idle easy screw where should that be set to / I need to get back to base.
kmiller is offline
Old 07-05-2005 | 08:51 AM
Kmiller, you said you put a 6.5 power valve in. you wrote you had 7.5-8.5 vaccum. if thats the case you should have a 3.5 power valve. you take your vac. reading and split it in half ,this a general rule of thumb.B.Miller
scarrab30 is offline
Old 07-05-2005 | 11:52 AM
Yes, on certain intake combinations you will see fuel come out of that vauum hose when the engine is off. Start out with the Idle-Eze about 1-1/2 turns out from seated.
RumRunner is offline
Old 07-05-2005 | 03:56 PM
kmiller's Avatar
Thats what I thought I will try to get more vacume first / then I will get a different powervalve........
kmiller is offline
Old 07-05-2005 | 04:09 PM
PatriYacht's Avatar
Where did you connect your vacuum hose for the gage? It should be connected to the intake manifold for a true reading. Some carb hookups are ported vacuum. There should be no gas in the line. If you don't have a fitting on the manifold, it's pretty easy to drill a hole and tap for a small pipe plug in one of the runners.
PatriYacht is offline
Old 07-09-2005 | 01:28 PM
kmiller's Avatar
I could not find my idle-eze screw untill this....... I pulled the carb base off and found the idle-eze screw but the hole was never drilled out under the stud..... Well I drilled it out and clean the carb up, looks like the base plate was newer then the carb body, also the Idle-Eze was all the way in and the primary transfer slot was around 3/16 long, re-adjusted and start over....... Might have been my vacuum problem also?? Well thanks for all the help
Kyle Miller SCS, M.I.
kmiller is offline
jayhawk261
6
09-29-2008 08:18 AM
kmiller
1
08-02-2004 07:06 AM
johnnyboatman
5
12-29-2003 01:45 PM
Monz
8
05-24-2003 10:51 AM
tssteph
3
04-08-2003 04:27 PM
