Procharger intercooler >
Old 06-28-2005 | 10:20 AM
jspeeddemon's Avatar
Default Procharger intercooler
After pressure testing my Procharger AW-504, I discovered that it was leaking. Has anyone had any luck cutting one of these apart and fixing or repairing the internals? I was wondering as well if a radiator shop couldn't make a custom radiator piece to fit inside this, since basically it is the same thing.
jspeeddemon is offline
Old 06-28-2005 | 10:33 AM
Default Re: Procharger intercooler
It depends on where its leaking, in my view. If the "tank" is leaking externally, it can probably be easily fixed. If the core is leaking water into the intake tract, (which it sounds like from your post) one or more of the inner tubes is either cracked or corroded through.
If it's the latter case, your best bet would be to trash it and buy a new one than to try to fix it and have a massive internal water leak destroy your engine.
Or, better yet, if your budget allows, upgrade to an R-Tech setup.
HARDCORE A/O is offline
Old 06-28-2005 | 01:00 PM
Turbojack's Avatar
Time for this.
Turbojack is offline
Old 06-28-2005 | 03:16 PM
Turbojack: Damnn, that sure is purty!
Old 06-28-2005 | 05:10 PM
Good news, we cut one side off the intercooler, where the 4 inch discharge tube is and the leak was two pin holes right there. Easily fixable. I did however do some research and found out that there are cores available to fix these intercollers or weld up your own for that matter, rather cheaply. If you can weld or have a friend who can, these Procharger is easy to make. It is easy to see after cutting it and looking inside. No way would I pay $1500.00 for a new one after researching this information. Type in intercooler on Ebay motors and you get a picture of how they make them. Lots of pieces and cores on there.
Old 06-28-2005 | 05:22 PM
I use several suppliers for intercoolers, and I have had some experience buying cores and welding . Yes you can buy cores and weld on your own tanks, but the welding is tricky. Too much heat and you can affect the brazing solder that holds the core together, getting a leak internally that is impossible to fix. When you go back to the core manufacturer they say it's your problem. Cost to fix a leaker is the same as the cost of a new core. Been there, done that. That's why we only buy welded and pressure-tested assemblies. We send our tanks to them. Costs more but it's the only way to control the liability for leakers. Cheapest thing for you to do is pay Procharger for a new core. If you found some pinholes now there's more of them that are almost leaking. Just my $0.02 worth.
tomcat is offline
Old 06-28-2005 | 05:36 PM
Thanks so much for your input. Tomcat I understand that you certainly build a nice intercooler, I'd like to able to, but at this point I don't want to afford one, just too many things on my plate. It is going to be very inexpensive to fix the pinholes and weld it back up. I am rolling the dice and if i get thru the summer I'll consider it a success. The only reason I found the leak was that I had a Jesel exhasut rocker arm bolt break and the water had no way to get out. I'll consider it a cheap water injection for detonation prevention Thanks again.
Full Force
Wanted
2
09-03-2008 09:17 AM
kennyo
Wanted
0
01-29-2008 05:29 PM
INDY27
3
08-14-2007 02:01 PM
wrenchman
2
06-30-2006 02:12 PM
azlineman
03-08-2004 10:00 PM
