Nasty Soot Problem >
Nasty Soot Problem
Nasty Soot Problem
Old 07-01-2005 | 08:20 AM
Perfectmix's Avatar
Default Re: Nasty Soot Problem
Thanks All,
I run 87 octane all the time. It is more of an annoyance than a problem, I am a clean freak and like my boat spotless at all times. Ya, Go figure. I will start with the air screws & timing that will be easy enough. Are there two or four screws per carb?
Thanks again, and Happy 4th of July All
Perfectmix is offline
Old 07-01-2005 | 08:21 AM
Perfectmix's Avatar
Originally Posted by FBRONCO
You might be burning oil.
They are not using any oil at all
Old 07-01-2005 | 12:04 PM
If Carb Is Vacum Seconds,the Should Only Be 2,if Carb Is A Double Pumper,you Will Have 4 On The Metering Blocks,2 ON ONE BLOCK,2 ON THE OTHER
JJONES is offline
Old 07-01-2005 | 01:09 PM
Sounds to me like you need to increase the low speed bleeds. If you open them up a couple thousands youll be soot free with better throttle response and a cleaner idle.
scarrab30 is offline
gerritm
19
05-25-2012 09:33 AM
poolshrk
04-07-2004 06:42 AM
bikinilover
10
06-12-2003 05:33 PM
Dave1972
5
11-11-2002 08:41 PM
CigDaze
23
02-01-2002 01:06 PM
