What did I break? >
What did I break?
What did I break?
Old 07-01-2005 | 07:54 PM
Scarab28's Avatar
Default What did I break?
Putting boat in hoist, Outdrive was trimmed all the way up,
I hit the throttle instead of the shift lever. Lots of U-joint noise and now no forword or reverse. Any ideas what broke?
Scarab28 is offline
Old 07-01-2005 | 08:18 PM
Default Re: What did I break?
You may have broke the u-joint! Remove the drive ande start from there.
TomR is offline
Old 07-01-2005 | 09:43 PM
Outdrive1's Avatar
Masher touches my
Sounds like u-joint or coupler. You need to remove the drive like metioned before and see what's going on.
Outdrive1 is offline
Old 07-02-2005 | 05:52 PM
Scarab28's Avatar
pulled drive - blew out both U-joints, both drive shaft ends, broke bell housing, ripped the bellows. Wow - all from one wave while docking the boat.
How does the U-joint assembly come out. I removed the retaining nut - now what?
Anybody got a bell housing laying around?
Scarab28 is offline
Old 07-02-2005 | 07:54 PM
FOUNTAINATLAST's Avatar
I'm guessing when you pulled the drive the joints were broken and the shaft stayed in the gimbal bearing??? The shaft will just pull out with a little effort, it just slides through the gimbal bearing and into the engine coupler.
FOUNTAINATLAST is offline
Old 07-02-2005 | 11:24 PM
Scarab28's Avatar
I broke both the shaft that slides into the gimbal bearing and the shaft that goes to the upper gear. The shaft connecting to the gear is the one I need help getting out.
Scarab28 is offline
Old 07-03-2005 | 01:14 AM
Lofty's Avatar
If you can't find a bell housing out your way I know I've got a few. Let me know.
Fionn
[email protected]
925.952.4240
510.541.8124
Lofty is offline
TYPHOON
OPA/The Jersey Boyz
7
01-09-2007 07:03 PM
GregP
07-14-2004 09:19 PM
Pure Energy
05-27-2004 08:28 AM
Audiofn
03-16-2004 09:55 PM
