Exessive steam >
Exessive steam
Exessive steam
Old 07-11-2005 | 08:27 AM
MnFastBoat's Avatar
Charter Member#157
Default Exessive steam
Sucked up some milfoil this past weekend
Went home and flushed every hose on both motors
Went back out that night and noticed more steam coming from the port motor then the starboard.
Anyone tell me why?
I did notice that my exhaust risers are warmer on that motor.
How can I flush out my risers?
Is that star plug removable?
Thinking I would have to reverse flush them.
This Cat is trying to keep up with the Big Dogs
MnFastBoat is offline
Old 07-11-2005 | 02:22 PM
Wobble's Avatar
SORE MEMBER
Default Re: Exessive steam
Are you sure your impeller is good in the port motor. If it was replaced were there any pieces at the intake to the oil cooler?
Wobble is offline
Old 07-11-2005 | 02:47 PM
MnFastBoat's Avatar
Charter Member#157
Impellar was fine
all hoses were back flushed extensivly.
With the exception of the exhaust riders. Not sure how to back flsuh these. But was able to have water flow out the tips flushing in the normal flow.
Old 07-11-2005 | 03:02 PM
Wobble's Avatar
SORE MEMBER
I assume water temps were normal, so stuck t-stat not likely?
you back flushed from raw water pump out through outdrive?
1 1/4" armored hose.
The mercruiser t-stat housing can corrode and restrict water flow as can the exhaust at the water inlets.
Wobble is offline
Old 07-11-2005 | 04:27 PM
MnFastBoat's Avatar
Charter Member#157
temps normal
back flushed ALL hoses
new thermostates as of this May. So no corrosion there.
Am worried about partial blockage in the risers however.
kemiller
8
05-06-2007 11:06 AM
cstobe
12-03-2006 05:51 PM
86formula242ls
05-24-2006 08:43 PM
Danny_Ocean
9
02-28-2004 03:41 PM
