Water Pressure, A diffrent question.... >
Old 07-18-2005 | 10:05 AM
BZ's Avatar
BZ
Default Re: Water Pressure, A diffrent question....
Thanx for all of the input we moved them to after the raw water pump and b/4 all of the coolers and they worked great...same oil tem water temp and the poped off at 15psi and maxed out at around 19-20 psi hope this helps the motors over the long run......BZ
BZ is offline
Old 07-18-2005 | 04:41 PM
RLW
It doesn't matter where the relief valve is plumbed as long as it is after the seawater pump discharge and before the inlet to the engine.
If you read Wally's post it states that there is more water (volume) than could be imagined. Do not forget that you are controlling, PRESSURE. There is more than adequate volume to cool the oil and engine even after the relief valve opens.
RLW is offline
StrikinLightnin
Fountain
22
09-07-2007 10:30 PM
ls1nova
8
06-13-2007 09:27 AM
toolbox
Fountain
10
02-10-2005 06:13 PM
toolbox
18
06-12-2004 04:46 PM
outlawinil
2
04-22-2004 04:19 PM
