edelbrock heads on a 365 >
Old 07-13-2005 | 08:09 PM
Default edelbrock heads on a 365
Has anyone had good luck running edelbrock marine heads with a 454 mag .100 dome.
heads are 110cc oval port .
I understand it will need premium fuel, but what hey it is boating.
Running a comp cam 226 236e duration .544 .547e lift.
the engine builder is questioning the clearance issue??
I have run the heads on a very very similar piston.
or do you think he wants to sell me more parts?
I am in the process of getting a new short block 454 mag 365.
thanks for the help.
BOATING ON A BUDGET is offline
Old 07-13-2005 | 08:42 PM
Default Re: edelbrock heads on a 365
What is your current static compression ratio with that piston?
1BIGJIM is offline
Old 07-13-2005 | 08:52 PM
How would I check the static pressure?
I talked to edelbrock before I bought the heads (other pistons).
and they said I should be ok
I called keith black the maker of pistons and they said it should be aprox 9.5:1 so?
It is torn down getting a new block now.
Old 07-14-2005 | 12:44 PM
737jetmech's Avatar
I have run them for 2 seasons with no problems. Compression ratio 9.25 to 1 . Edelbrock torker plus cams @ 114 degrees.Aluminum heads give you about 1 compression point over iron heads prior to detonation. Higher head sink rate.87 octane for me @34 degrees total timing.
Bob
737jetmech is offline
Old 07-14-2005 | 04:54 PM
Are you using the K.B. KB203030 .133 dome? I ran a set for a while until I spun a bearing. Gave me around 9:1 with
118 cc heads.
1BIGJIM is offline
Old 07-14-2005 | 05:05 PM
I was running kb203 shave down and balanced .103 dome.
spun a brg 3 times with that stuff. going to install a oil temp gouge now.
hopefully soon.
aTX427
49
02-24-2011 01:08 AM
Jrock
Wanted
0
02-13-2008 06:46 PM
JimV
11
05-10-2005 04:35 PM
Madmax
14
11-21-2003 12:16 PM
Madmax
4
03-26-2003 08:38 AM
