Marine Lubrication
#1023
Originally Posted by zahndok
Would the newer viscosity Mobil 1 75-140 gear oil be a better choice for high horsepower bravo drive protection than the original viscosity 75-90? Anybody used this oil or have any thoughts?
You will be doing just fine using a 75w-140 gear lube in your lower unit.
Happy Holidays, Ken
#1024
Originally Posted by minxguy
Yes, the only draw back may be a slight horsepower loss due to the heavier viscosity. I have used nothing but a full synthetic 75w-140 GL-5 in my lower units, both Alphas and Bravos for the past 10 years with no problems. I personally perfer a heavier viscosity oil because viscosity is your first line of defense against wear. Additives like zinc and EP additives are reserve boundry lubricants, they only work when the oil film has been compromised.
Happy Holidays, Ken
Happy Holidays, Ken
#1025
Originally Posted by Rage
Any idea how the Hp loss from Redline Shock Proof (Heavy) Gear Lube would compare with the 75w-140?
#1026
Ken, Thanks for the feedback on using 75-140. Is the 75-140 a higher viscosity than the Merc Hp green stuff? I'm using the Merc now and am eating lower gears. I'm looking to change to something heavier in viscosity.
#1027
#1029
Still interested in suggestions. For general use in Yamaha Wave Runners.
Ken
#1030
Rage, you can use any high quality motorcycle oil in your Waverunner. All the benifits that your boat engine receives from quality oil , your watercraft engine will receive. If this was mine I would use Spectro 4 10w40 motorcycle engine oil. It is a straight petroleum with the uptreat in anti-wear chemistry. change it once a year.
Ken
Ken
