Marine Lubrication
#921
[QUOTE=sleeper_dave]Can you guys take a look at these results and tell me what you think?
Start with the oil. 26 hrs on oil. 1 quart added @ 5 hrs on oil, filter changed and 1.25 quarts added @ 22 hrs on oil. Rebuilt 502 w/ 130 hrs on it, stock, carb'd. Merc 25w40.
SD, the antiwear package is still very strong, well over a thousand parts per million of zinc and phosphous. Most auto products start at a thousand PPM. The oil has thinned to a very light 40, probably due to the fuel dilution. But, you purchased a 40wt and it came out a 40wt. It is what it said it was on the label. The range for an SAE 40 at 210 in SUS is 70 -85 seconds, your oil was at the low end. The fuel dilution has affected the lubricating properties of the oil no doubt causing some wear, but then you do mention the rebuild.?As a lubricant it has held up well. (From a viscosity and additive standpoint.) If you still have a fuel diluton issue, I would run a XXw50 next year. The 50 side of the lubricant can stand up longer to fuel. Ken
#922
Originally Posted by Hydrocruiser
The gear lube has little if any ZDDP anti-wear additives in it and your iron levels are very high showing significant wear.
Pull the carbs and get them checked out if not rebuilt or replaced. I would compression test the engine FIRST as a bad ring job can lead to fuel contamination as well and if it isn't right go after the rebuilder.
What lube were you running?
#923
Originally Posted by sleeper_dave
I got the dyson analysis too, on the oil.
here's what he said
here's what he said
#924
http://www.lubecontrol.com/
I think the motor is running a bit rich at idle, the plugs looked kind of black when I pulled them to fog the cylinders. I will be changing the plugs and adjusting the carb next spring. I'll probably also pull apart the carb and check for the proper jets, and maybe even do a compression test.
I plan to run the M1 V-twin 20/50 next year. I'll use the amsoil filter terry suggests, or an M1 filter. I don't think i'm going to try the lubecontrol, i might give the fuel additive a try. I'll change the filter, top off, and have an analysis done at 20 hrs. Hopefully it'll look a lot better.
here's the results from dyson on the gear lube:
Outdrive was running the merc HP gear lube. I'll probably stick with that for the drive. 70 hours on it and it doesn't look too bad. Maybe i'll change it 1/2 way through the season next year for good measure.
#925
Originally Posted by minxguy
Although there is no zinc in the gear lube there is phophous and molybdenum. I would belive that these two additives are the anti-wear chemestry in this gear oil. Ken
#927
I have 360' of frontage with a ditch that is about 45* on one side. Only way to mow the steep side is with a cheap push mower of which I have ruined a couple due to the splash lubrication not working at that angle. On this last one I threw in some v-twin oil and to my amazement this mower has outlasted the previous two combined, both with similar Briggs engines.
It is a little slow to get up to speed when cold though
Hows that?
Hows that?
#929
Oh....
After I drain the Merc hypo oil from my OD, I save it and use it on the chain that runs the auger on my 3 pt. hitch 7 foot snow blower. Chain still has oil film on it at the end of winter
#930
Hows that?
Hows that?
