Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 01-02-2007 | 07:19 AM
  #1061
Default Re: Marine Lubrication
Originally Posted by Rage
That is good to hear that you can still get a full synthetic at lower viscosities since Mobil1 has reportedly abandoned full synthetic except for the high viscosity motor cycle oils.
Spectro Oil blends a full synthetic(group 4) PAO in 0w-40, 5w-40, 10w40,10w50, 15w50, 20w50.
Ken
minxguy is offline
Old 01-02-2007 | 09:07 AM
  #1062
Rage's Avatar
Originally Posted by Hydrocruiser
You know your stuff 02man..
Here is my take:
The MCO (Like V-Twin) and HDEO (Delvac 1) are still Group IV/V and they have always been my top picks.
Oil fanatics are pizzed off to say the least...check this out..
I borrowed this from an oil thread...
Mobil 1 and Castrol Syntec have betrayed the public and ruined the credibility of synthetic oil.
Group III and GTL may be , or could be, as good or even better than PAO ...but why do oil companies feel it is ok to mislead us and price gouge as well?
Mobil 1 used to be under $4/qt when it was a true synthetic. Group III faux synthetics used to cost from $1 something / qt to $4/ qt.
Now Mobil 1 Group III Faux costs $6 /qt to $7 /qt... is it any wonder that I feel ripped off , and I am now strongly anti-Mobil 1?
Redline, Castrol GC, Amsoil, Pennzoil Platinum [on sale], Delvac 1, Delo 400, Rotella T and Rotella 5W-40 faux syn, Trop Arctic/Havoline/Motorcraft are on the 'A' list and Mobil 1/ Castrol Syntec are on the 'S' list.
I especially like Redline, it is now about the same price as M1 and Redline is still the best oil I've tried.
I am now using Penzoil/Amsoil/Redline or Delvac 1 in my cars and V-twin; Amsoil Severe Service Racing or Redline in the boat.
What is it about Redline that makes it the best oil you have ever tried?
Rage is offline
Old 01-02-2007 | 10:30 AM
  #1063
Knot 4 Me's Avatar
We know 15W-50 M-1 is a better choice.
Agree, but I'm still curious as to what Ilmor is putting in the motors.
Knot 4 Me is offline
Old 01-02-2007 | 02:10 PM
  #1064
Hydrocruiser's Avatar
Redline and M-1 V-twin are mostly derived from Group V bases and therefore can go beyond 500*F before being destroyed. Most oils are shot at or around 400*F.
Hydrocruiser is offline
Old 01-02-2007 | 02:12 PM
  #1065
Arrow Re: Marine Lubrication
I called today and they use 15W-50 M-1 interestlingly enough as does Sterling.
Old 01-02-2007 | 02:22 PM
  #1066
The question becomes do we continue with M-1 15W-50 from a number of you?
My answer is that in an offshore boat you need the best edge you can get if you are to see the most longevity from your engine. I like a Group IV/V synthetic best.
Here are the 2007 2,000lb. synthetic oil gorrillas:
M-1 V-Twin 20W-50/Redline 20W-50/RP 20W-50/Amsoil Severe Service 20W-50/Spectro 20W-50.
The list is getting shorter.
Yes...15W-50 M-1 is still a great product and i use it as well. It is NOT on the list above however.
Old 01-02-2007 | 02:24 PM
  #1067
Knot 4 Me's Avatar
Hydro, what's your take on the new Amsoil 10W40 marine oil that is FC-W certified? Supposed to be an acceptable replacement for Merc 25W40.
Old 01-02-2007 | 02:27 PM
  #1068
Knot 4 Me's Avatar
That's what I figured. Thanks!
Old 01-02-2007 | 04:00 PM
  #1069
Mercury 25W-40 is a blend of straight 25 wt and 40 wt oils ...so I am told. The overall viscosity can not therefore be compared to a multi-vis oil as it supposedly does not have polymers that react and increase viscosity with heat. So the lowest viscosity the oil can be said to perform at is 25wt. Therefore a 10 wt is too light.
The bottom line is Merc's product is more comparable to a straight weight 40.
So using a 10W-40 multi-vis oil in place of a 40 wt will probably lead to some type of problems and most notably probably increased wear.
We hear that the following oil viscosities are used routinely and successfully;
15W-50
25W-40 Mercury
20W-50
15W-40 Amsoil Synthetic ("pleasure boats")
30wt if less than 50*F
40 wt for temps between 75-85*F
50wt for temps over 85*F
For 4-stroke outboards I like a 10W-40 such as Amsoil's or 10W-40 V-twin.
Old 01-02-2007 | 07:00 PM
  #1070
To address more concerns about Group III synthetic oils...
While I prefer Group IV/V bases, modern group-III oils can nearly match the performance of PAOs at about half the price. Because of this, PAO based oils are rapidly disappearing. There are new processes being investigated which may significantly cut the cost of producing PAOs, and make them an important component of oil again.
