Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 01-04-2007 | 05:47 AM
  #1081
Default Re: Marine Lubrication
Originally Posted by o2man98
Your are correct when you say that 10W and SAE30 are different specs. But so are 20W and SAE20. SAE 20 and SAE 20W are two totally separate monograde classifications. SAE 20 describes the high temperature viscosity of the oil and SAE 20W describes the low temperature cranking capability of the oil. Not all xW ratings are made at 0* F. While the high temp viscosities are rated at 100C or 212F, the "w" ratings use low temperature cranking viscosities at different temperatures.
SAE Viscosity-Cranking (cP)
Grade - Max at temp oC
0W - 6200 at –35
5W - 6600 at –30
10W - 7000 at –25
15W - 7000 at –20
20W - 9500 at –15
25W - 13,000 at –10
An oil can be classified as a multigrade SAE 20W-20 if the oil can meet both the low temperature cranking viscosity of 9500 cP at –15C and the 100C high temperature kinematic viscosity requirement between 5.6 and 9.3 cSt. The AMSOIL motor oils listed above meet both the low temperature requirements of SAE 10W and the high temperature requirements of SAE 30. Thus the products are true SAE 10W-30 and SAE 30 oils.
Ken
What you have stated is true for any multi-viscosity oil, any brand. Hence the term multi-viscosity.
I am using 0 degrees as a reference for Saybolt Seconds. people seem to grasp the concept a little easier.
I realize that the cST/cP is more universaly accepted.
Ken
minxguy is offline
Old 01-04-2007 | 09:07 AM
  #1082
Ken
Saybolt or SUS is measured at 212F and 100F.
o2man98 is offline
Old 01-04-2007 | 10:22 AM
  #1083
That is a wonderful graph. Perhaps now people can "visualize" a SAE 90 gear oil is not necessarly thicker than a SAE 50 engine oil.
This comparison chart does not get to the "W" temp for oil grading. It states on the bottom that the "W" grades are classified on low temp properities. 100F is not low temp properties for a "W" rated oil.
Ken
minxguy is offline
Old 01-04-2007 | 03:07 PM
  #1084
Knot 4 Me's Avatar
Originally Posted by Hydrocruiser
I got a bunch of PM's that expressed discontent with M-1 15W-50 EP allegedly changing over to GRP III.
Am I happy with this decision? Not in the least!
Is 15W-50 still a good product ...yes.
Is there something out there for around $6.00/qt that remains a true Grp IV PAO with excellent ZDDP additives etc?
Yes!!
What is it?
Royal Purple 20W-50 sold in 5 gallon pails and shipped UPS free to your door for $6.25/qt and $6.99 in single quarts. While at it their gearlube is excellent and a PAO product as well.
How do I get it?
http://www.rpmoil.com/index.php?main...b62a8a9bc42262
Is this what I would use if I decided not to use V-Twin @ $9.00/qt. Yes.
I am hence moving my 15W-50 M-1 use over to RP 20W-50 as it is a PAO/ better value and quite comparable to V-twin as well for $6.25/qt in bulk 5 gallon units with free UPS delivery in the 48's..
Hydro, is this their regular 20w50 that is a PAO or is it their XPR 20W50 that is a PAO? There is $6/quart difference in price bewtween the two oils at Jeg's so it makes me wonder if the XPR is the PAO and not the regular 20W50.
Knot 4 Me is offline
Old 01-04-2007 | 03:29 PM
  #1085
Hydrocruiser's Avatar
I am working on that..good question.
Hydrocruiser is offline
Old 01-04-2007 | 03:42 PM
  #1086
Arrow Re: Marine Lubrication
The tech told me they have not gone to Grp III bases and said all RP products are GRP IV or V.
Let me know what you hear.
Old 01-05-2007 | 07:49 AM
  #1087
Knot 4 Me's Avatar
Thanks. The XPR line must have a way beefier additive package to justify the upcharge.
Old 01-05-2007 | 07:57 AM
  #1088
For $6.00/quart, it has to be a lot more than a uptreat in additive.
Ken
minxguy is offline
Old 01-05-2007 | 09:37 AM
  #1089
sleeper_dave's Avatar
I'm going to put an oil thermostat on my boat, because the oil wasn't getting past 140°F for most of last summer.
Should I get a 180°F thermostat, or a 200°F thermostat?
http://www.racerpartswholesale.com/mocal.htm
sleeper_dave is offline
Old 01-05-2007 | 10:03 AM
  #1090
Rage's Avatar
The question becomes do we continue with M-1 15W-50 from a number of you?
My answer is that in an offshore boat you need the best edge you can get if you are to see the most longevity from your engine. I like a Group IV/V synthetic best.
Here are the 2007 2,000lb. synthetic oil gorrillas:
M-1 V-Twin 20W-50/Redline 20W-50/RP 20W-50/Amsoil Severe Service 20W-50/Spectro 20W-50.
The list is getting shorter.
Yes...15W-50 M-1 is still a great product and i use it as well. It is NOT on the list above however.
How do you get and where do you go for the best pricing of the Redline 20W-50 and the Spectro 20W-50 Platinum?
Rage is offline
