Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 01-12-2006 | 03:51 PM
  #481
Hydrocruiser's Avatar
Arrow Re: Marine Lubrication
Originally Posted by Strip Poker 388
I would think the Fram HP 6 is made close to the same way?
The Racing HP 6 flows like crazy and is built to take a ton of pressure...ever notice that on Merc racing engines...the "pro engines" there is a huge ring around the filter where it connects the engine that you can screw to tighten...wonder if any ever blew off or apart during a race?
Hydrocruiser is offline
Old 01-12-2006 | 05:24 PM
  #482
Default Re: Marine Lubrication
I was wondering the same thing. New Powerboat came a week or so ago. Page 41 shows a quad rotor 1500hp Sterling. There's a stainless steel band around the HP-6 near its base. I mentioned it to Strip (Rob) a week or so ago. Lou
Lmarth is offline
Old 01-12-2006 | 06:57 PM
  #483
Strip Poker 388's Avatar
Rob
I just got of the phone with Wix on the fuel pressure filter/water seperatos .There burst presure was 280psi..The fuel presure housing is thiner than the oil filters.
I would not think that the clamp would be for keeping the filter from expanding.
Rob
also once on a new motor the oil pump bypass valve stuck .Priming the motor before bust off the oil pressure when out of site all it did was blow the rubber gasket .it pushed out and spewed oil everywere. But the filter didnt burst.But it was a short burst because it stopped a 1hp drill
Strip Poker 388 is offline
Old 01-12-2006 | 08:08 PM
  #484
the hose clamp is to keep it from loosening with vibration. there is a stop built into the mount. we safety wire anything else and the k&n makes easier work of it.
audacity is offline
Old 01-12-2006 | 10:02 PM
  #485
Rob
Something simple
Joe ya never got back to me on that pm I sent ya on the imco's?
Old 01-12-2006 | 10:17 PM
  #486
i know....jeff keeps going back and fourth on what he wants...we had yet another change in plans,,,i'll get back w/ya next week. sorry again!
audacity is offline
Old 01-14-2006 | 03:31 PM
  #487
Smile Re: Marine Lubrication
Is Mobil 1 SCH 75w90 the same as Mobil 1 SAE 75w90 with a API service GL-5? Thanks for any replies.
CrazyCat57 is offline
Old 01-14-2006 | 06:04 PM
  #488
fyi..Mobilube PTX is not sold in th US - except by Porsche dealers at a 5X markup.
Mobil's Specs:
Mobilube PTX (synthetic) 75W-90 GL-4, GL-5
Mobilube 1 SCH (synthetic) 75W-90 GL-5,PG-1,PG-2
The LS 75W-90W; GL-5 that is on most auto store shelves around here..http://www.mobil.com/USA-English/Lub..._LS_75W-90.asp
Are they all the same?..I am not sure..but if it's rated GL-5 it should not matter. We think Merc's HP is a semisyn between maybe a GL-4 but probably not a GL-5..just guessing...GL-5 is the highest "official" rating...and these ratings pertain to the load handling ability of the lube that relates to it's additive strength.
Old 01-15-2006 | 11:31 AM
  #489
Is the Mobil 1 75W90- GL5 synthetic ok to use in a 1992 King Cobra cone clutch drive? My omc dealer said to use Mobil 1 SCH 75w90 synthetic but all that I can find is the Mobil 1 75w90-GL5 synthetic Thanks
Old 01-15-2006 | 07:29 PM
  #490
I would not hesitate to use any Mobil-1 75w-90w GL-5 in your application. There is little difference between the formulations according to the company.
