Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 01-23-2006 | 03:43 PM
  #501
vandy021's Avatar
Default Re: Marine Lubrication
Originally Posted by vandy021
Just had surgery so I've been down. Anyway, the oil business is good. We have started out strong this year.. We are also awaiting a price increase on all finished lubes. I feel something coming........
Whoa how I can predict the future... 40 cents on conventional and 60 on synthetics on March 1st.. Who the f***k saw that one coming..
vandy021 is offline
Old 01-23-2006 | 04:00 PM
  #502
formula31's Avatar
A lot of ppl have been hating on the Mobil 1 EP 15w50. It's still a good oil for boaters who aren't out beating the sh!t out of their engines...
Speaking of the Mobil 1 15w50, does it still have the same amount of ZDDP? And if so, how? Its labeled as automoive and word has it the government/oems forced reductions of ZDDP in auto oils to solve catalytic converter problems.
formula31 is offline
Old 01-23-2006 | 04:12 PM
  #503
vandy021's Avatar
I'd have to check with my Mobil Rep.
When the brain surgeons brought out the EP. They marketed it as having 36% more anti-wear additives which is ZDDP
37% more cleaning agents
50% more SuperSyn
This was compared to Mobil 1... Now Mobil 1 was full of the stuff already. Maybe another wrench head could answer it quicker than I?
vandy021 is offline
Old 01-23-2006 | 04:33 PM
  #504
Hydrocruiser's Avatar
Arrow Re: Marine Lubrication
50% more SuperSyn
My take is that the increased anti-wear and detergency additives now present in the current M-1 15W-50 EP formulation offer two distinct advantages over the previous formulation:
- The first being it offers the ability to go for extended periods in automobiles while keeping "wear" at a minimum and the engine clean and particles dispersed for out to 12,000 miles and is safe to do so if using a good oil filter.
-The second being it offers more anti-wear properties for marine use along with better detergency than the previous formualtion and can probably be extended to the maximum recommended drain interval of up to 50 hours....certainly 30-40 hours is reasonable I would gather from tests I have seen...in stock; non- hopped up or non-blower applications.
While not having as much ZDDP as V-twin it is a good choice for general offshore use; for racing; hopped up or blown engines I'd go with 20W-50 V-Twin and would change it more frequently because of the potential for gas contamination into the oil.
Hydrocruiser is offline
Old 01-24-2006 | 11:20 AM
  #505
50% more SuperSyn
EP additives in a GL5 formulation are mostly a sulfer or chlorine base additive. Ever smell a GL5 product? It smells nothing like an engine oil which has ZDDP.The smell is the hypoid additive package sulfer & chlorine, which will offer a lot more protection than ZDDP. Ken
minxguy is offline
Old 01-24-2006 | 01:31 PM
  #506
Is that 40 cents each on finished lube in quarts or gallons? How about bulk pricing?
minxguy is offline
Old 01-24-2006 | 04:10 PM
  #507
Sulfur or Phosphorous; Molybedium or Antimony or any other sacrificial "soft metal".
When the oil is "squeezed" away the sacrificial lubricant qualities of these agents protects against wear and they are destroyed in small amounts instead of the gears.
Mercury HP... lots of antimony...excellent but be ware that it is a poison like lead.
Redline... tons of sulfur.
Royal Purple...lots of moly
Mobil-1.. Phosphorous and moly.. I believe
Amsoil ...not sure what the new formualtion has in it.
Old 01-25-2006 | 06:26 AM
  #508
EP additive.............a lubricant additive that prevents sliding metal surfaces from seizing under conditions of extreme pressure(EP). At the high local temps associated with metal-to-metal contact, an EP additive combines chemically with the metal to form a surface film that prevents the welding of opposing asperities(small metal projections on the surface left from machining), and the consequent scoring that is destructive to sliding surfaces under high loads.Reactive coumpounds of sulfur, chlorine, or phosphorus are use to form these inorganic films. If moly is being used the oil would be black when new, never heard of antimony being used. Ken
minxguy is offline
Old 01-25-2006 | 06:46 PM
  #509
Well Royal Purple dyes it's product purple or it would be blackish as Redline is.
The Mercury HP shows a caution on its's bottle about how poisonous Antimony is...or at least it used to...and I read that Antimony is an EP.
Who uses chlorine except the additives with Teflon that don't work?
Old 01-26-2006 | 03:48 PM
  #510
The new Amsoil 20W-50 MCV looks to contain Phos and Zinc along with a little moly but I am not sure of the actual form of Moly.
The other thing I would like to mention is I believe I see some confusion growing here on the last few posts. Please do not confuse Mobil 1 EP with "EP" as in Extreme Pressure additives. M1 EP will not have "EP" in it. "EP" is contained in gear lubes not motor oils.
By the way the new Amsoil Motorcycle 20W-50 oil will be going up in price Feb 1. About $.35 per qt at dealer cost.
Ken
o2man98 is offline
