Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 01-26-2006 | 06:57 PM
  #511
Hydrocruiser's Avatar
Default Re: Marine Lubrication
Originally Posted by o2man98
The new Amsoil 20W-50 MCV looks to contain Phos and Zinc along with a little moly but I am not sure of the actual form of Moly.
The other thing I would like to mention is I believe I see some confusion growing here on the last few posts. Please do not confuse Mobil 1 EP with "EP" as in Extreme Pressure additives. M1 EP will not have "EP" in it. "EP" is contained in gear lubes not motor oils.
By the way the new Amsoil Motorcycle 20W-50 oil will be going up in price Feb 1. About $.35 per qt at dealer cost.
Ken
M-1 EP = Extended Performance...as in extended drains...but they do have more ZDDP to achieve that and the components of ZDDP are EP lubes...confused yet?
Hydrocruiser is offline
Old 01-26-2006 | 07:54 PM
  #512
Arrow Re: Marine Lubrication
Ken
Amsoil Marine Synthetic Lube has shown good results last season. I like the "seal conditioners" they use specific to outdrive seal materials that help prevent leaks and water damage. It is thinner and that means it can shead heat faster and better and also the lower viscosity means less paracitic loss.
It is the one to beat in my humble opinion.
Old 01-27-2006 | 11:38 AM
  #513
Originally Posted by Hydrocruiser
Well Royal Purple dyes it's product purple or it would be blackish as Redline is.
The Mercury HP shows a caution on its's bottle about how poisonous Antimony is...or at least it used to...and I read that Antimony is an EP.
Who uses chlorine except the additives with Teflon that don't work?
Some of the engine oil additive manufactures ie;Duralube, used a chlorinated paraffin additve in their product to claim EP. Ken
minxguy is offline
Old 01-27-2006 | 07:08 PM
  #514
Chlorinated paraffin’s:
They show how their oil will perform in a pressure test that has a torque wrench that puts pressure on a bearing and a round but rough surface that is turning in the test oil. They show how by adding their oil the wear is greatly reduced. This can be done with household bleach but you would not want to put any of that in your engine because it’s corrosive. The Chlorinated paraffin’s are also corrosive to the light metals in your engine. The lead in your engine bearings is subject to corrosion or acids that can build up. When the chlorinated paraffin’s come in contact with moisture or water of any kind they turn into hydrochloric acid and can become acidic to the lead in your bearings. So the reduction in wear shown by the torque wrench test is only one realm of wear that goes on inside your engine. Acidic or corrosion wear is another type and that is why I would never use an additive containing any type of chlorinated product.
Old 01-31-2006 | 06:15 AM
  #515
Do not use any oil additive that claims EP protection in a engine for reasons stated above. They should only be used in a application that is sealed, ie;a differential, transmission, transfer case etc. But if you are using a quality product, you shouldn't have to additize the lubricant with an additive. The blender should have done that for you. All lubricating oils are a balanced chemical formula, by adding an aftermarket additve you no longer have a balanced formula and could be doing more harm than good, like adding an EP product to you engine oil. Sure it looks good when demonstrated with the Falex Bearing Tester, but in the real world it not the best application. Ken
minxguy is offline
Old 02-01-2006 | 02:21 PM
  #516
vandy021's Avatar
Some you have lost it.. EP with the Mobil 1 is for extended performance not Extreme Pressure as they put in Industrial Gear Oils. The EP package put in those "Industrial" oils is for the shock load that is put on the gears. No one in their right mind would put in EP additive in a motor oil. And yes, there are some EP's put into closed systems as stated in there above.
Regards
vandy021 is offline
Old 02-02-2006 | 09:51 PM
  #517
Regards
Phosphorous and Zinc are both potentially used as extreme pressure additives and are present in lubes and as anti-wear additives in oil...it all depends on the molecular form and content %.
Best regards!
Old 02-03-2006 | 09:09 AM
  #518
vandy021's Avatar
Kudos you sound like my ExxonMobil engineer. They aren't used though as a EP in auto world.
vandy021 is offline
Old 02-07-2006 | 04:38 PM
  #519
I was asked if too much ZDDP is bad...
Answer...usually not if the manufacturer added and tested it. If too much is added after manufacturing then it's possible to have too low a detergency ratio and the oil can sludge up.
Old 02-10-2006 | 04:26 PM
  #520
A few asked me what I would suggest putting in their drive case this summer.
Well I decided that if a company deserves your business they should make a product specific to marine use.
So that's either Mercury Hp or Amsoil Marine Synthetic
...my money is on Amsoil Marine gear-lube this season as i have heard many stories of how it will not foam...handles water better than most and has "seal conditioners" other's may not...
