Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 12-08-2005 | 07:30 AM
  #411
bglz42's Avatar
Default Re: Marine Lubrication
Hydrocruiser said:
I see some diesel oils indicate on the label they are also compatible with gasoline engines. I guess you have to decide...overall I vote for not routinely using it.
Hydrocruiser also said:
The top rated non-synthetic oils from a recent study I came upon....
Hey, aren't those "diesel oils"?
bglz42 is offline
Old 12-08-2005 | 04:19 PM
  #412
Hydrocruiser's Avatar
Arrow Re: Marine Lubrication
Oh quit it with the "Hydro said stuff"....
Oils labeled "diesel" have harsher detergents for soot and carbon control... like magnesium and silicon. They are also high in ZDDP for anti-wear... They are the only choices for a diesel for sure...some feel good for any iron block rig...but they can be hard on aluminum parts and not for use in aluminum block engines so say the gurus. So not for your family vehicle...but marine use? Looking good after looking into it more...
They are probably the best of the lower priced oils. Rotella goes for 6 bucks at Home Depot in 5 qt plastic containers. With a $2.99 A/C filter it's the best value out there if you want to pay less...and some do.
Not to worry my synthetic friends....you guys have much tougher film strength and outperform all those other guys..
Hydrocruiser is offline
Old 12-08-2005 | 05:14 PM
  #413
bglz42's Avatar
Yawwnn...
bglz42 is offline
Old 12-08-2005 | 07:58 PM
  #414
Yawwnn...
I forgot...and I am sincere...what is your take on what is best to use?
  #415
bglz42's Avatar
Hey Hydrocruiser, I'd like you to ask your "gurus" if they've ever heard of the Duramax diesel... Lot's of aluminum in that. Ask them to go to Bob's site and look at the UOA's on Duramax and Cummins diesels running conventional 15w40 HDEO's. Virtually no aluminum showing up in the oil. Where's that evidence of being "hard on parts"? My Cummins has aluminum pistons. And 215,000 miles. UOA's show almost no aluminum wear.
Jim
bglz42 is offline
Old 12-08-2005 | 08:04 PM
  #416
bglz42's Avatar
Ok, here's my humble opinion:
On extended drains in boats: synthetic 15w40 or 15w50 or 20w50
On 20 hour changes in boats: Kendall 20w50, any HDEO or Merc 25w40
In my wife's E430: Mobil 1 0w40 & 13k oil changes
Cummins: 15w40 HDEO anything
Everything else: HDEO 15W40 (Includes Trooper, Miata, Tracker, 1966 Massey Diesel)
bglz42 is offline
Old 12-08-2005 | 08:54 PM
  #417
Sounds fine...how many hours would you extend out to with a synthetic in a boat?
..and your wife has a great car...how do you like Benz's new 430 engine? I see a lot of S430 models out there as well...it's a six cylinder that has a good amount of HP and torque? Seems to be selling better than E500 or S500 models. Benz also wants a lot more $ for the 500 engine.
Old 12-09-2005 | 06:57 AM
  #418
bglz42's Avatar
In a hi perf BBC, I'd never go beyond 20 hours. That's why I don't use synthetics. I'd run synthetics out to 50 hours or so in a conventional (cruiser-style) engine, I guess. But I've had such good performance out of dino oils, that I use them to 50 hours in my Donzi's 351w and my old Trojan's 318 Chrysler. Never had an oil related issue.
The 430 is a V8.
Jim
bglz42 is offline
Old 12-09-2005 | 09:03 AM
  #419
The 430 is a V8.
Jim
You are very good at matching a specific product to a particular service requeirement and drain interval. The results you describe match that.
Oh the 430 is a V-8...I heard it is a smooth running high tech machine too
Old 12-11-2005 | 10:23 PM
  #420
IM4A2Z's Avatar
How about a lineup in suggested recommended order of Drive Oils/Gear Lubes?
Lot's of great reading here, Thanks
I was already a BIG fan of Mobil 1 Syn oils. 95 Yukon with 185K miles all on Mobil 1 10w30 and the Z06 gets 5w30. Previous boat had Mobil 1 as well.
IM4A2Z is offline
