Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 06-22-2006 | 04:32 PM
  #691
Default Re: Marine Lubrication
Originally Posted by minxguy
.................the micron rating on all the posted filters, are the ratings absolute or nominal? ken
What are you referring to???
Nominal = 50% @ "X" microns
Absolute = 98.7% @ "X" microns
The AMSOIL filter is absolute at 15 microns and the Mobil filter is absolute at 18 microns. The rest will go by the specific data mentioned.
All the figures above show the specific Efficiency at the specific Particulate Size.
o2man98 is offline
Old 06-22-2006 | 05:46 PM
  #692
Hydrocruiser's Avatar
Arrow Re: Marine Lubrication
Originally Posted by Rebel_Heart
Hydro - I have paid for an Amsoil membership because I am using the gear lube in my Bravo. What am I giving up if I use the Amsoil engine oil and filter? I was planning on using Mobil 1 and a Wix filter, but wondered if Amsoil's products are as good? I have new 540s and want to treat them right. Thanks.
Amsoil 20W-50 Severe Service Racing Oil and their oil fliters are great...excelent choices.
Hydrocruiser is offline
Old 06-23-2006 | 07:57 AM
  #693
Yes, thank you. Ken
minxguy is offline
Old 06-23-2006 | 08:28 AM
  #694
vandeano's Avatar
Mercury Mercruiser 25W-40 Synthetic Blend Engine Oil...What are some comments on this oil???
vandeano is offline
Old 06-23-2006 | 06:37 PM
  #695
As with all blends you don't know the ratio of synthetic to conventional oil. In many cases it is usually only about 20% synthetic.
The Blend is for 4-stroke outboards that were shearing down the conventional oil I hear.
Old 06-23-2006 | 11:22 PM
  #696
vandeano's Avatar
I read somewhere that Mercruiser oil has additive ingredients for the marine environment not found in regular automotive oil. Any truth to that and if so what it the ingredient?
vandeano is offline
Old 06-24-2006 | 01:37 AM
  #697
articfriends's Avatar
You need to be 100% sure your rings are seated before converting your motor to synthetic oil or you'll be pulling it back out of your boat.Everyone gives the example of chevy corvettes coming from the factory with mobil one but I have seen motors that were NOT fully broken in converted to synthetic too early and if the rings glaze she'll have high leakdown rates FOREVER,Smitty
articfriends is offline
Old 06-24-2006 | 01:38 AM
  #698
If anything it might have extra zddp which is crucial in flat tappet motors,Smitty
Old 06-24-2006 | 05:21 AM
  #699
vandeano's Avatar
That might explain the problem I had with my rebuilt engine. Thinking it was a roller motor, I didn't know it would of been a problem. Im sure glad I used Mercruiser synthetic blend on my new crate.
vandeano is offline
Old 06-24-2006 | 10:08 AM
  #700
Here are some additives most premium oils have...Mercury has what I conisder to be a chemistry similiar to Kendall 40wt..in a sample we looked at of Mercury oil we found no special formulation as one might have expected...I feel the best oil out there because of it's tough base and extreme corrosion resistant formulation remains M-1 20W-50 V-Twin for the marine environment. No slam but Mercury is NOT in the oil business.
Characteristics of Additives
Additive Name Characteristics
Detergency & cleaning action Phenaltes, Sulphonates, Naphthenates Interacts with varnish or sludge to neutralize and solubilize.
Dispersancy PBI (Polyisobutylene) Succinimides Dispersants are soluble in the oil and have a polar end which attracts and binds to contaminants preventing settling and adhesion to metal surfaces.
Antifoaming Silicone Polymers (very low concentrations) Not really necessary for diesel engines in properly designed systems, but provides anti-foam in gearbox and also at the refinery during blending.
Pour Point Polymethylacrylate Used in SAE 30 grades and below to ensure point criteria are met.
Anti-wear load carrying ZDTP (Zincdialkyldithiophosphate)ZDDP (Zincdiethlydithiophosphate) Chemicals react with surfaces forming films which have a slower shear strength than parent metal.
VI Improvers Polymers of: Methacrylate Acrylate Olefin Styrene-Butadiene Increase in relative viscosity more at high than low temperature.
Rust and corrosion inhibition Sulphates, Thiourea type chemicals Chemically absorbed onto bare metal surfaces providing protection and neutralization.
