Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 09-28-2006 | 06:14 PM
  #821
Default Re: Marine Lubrication
I know this is a deviation, but I have read all these posts and have a question even though I feel like I am quite knowledgeable after all of your help from the past few hours of reading. For my tow vehicle-an Avalcanche 2500 w/ the 496 C.I. motor that never goes north of Tampa. I have never seen colder than 25 degrees. For 6 mo's low is 80 and high is 95. Book says: use 5W-30, but 10W-30 is acceptable from 0* F and up if 5W-30 is not avail. The book says do not use SAE 10W-40, SAE 20W-50 or any other viscosity grade oil not recommended. What do you all think for me in the summer and winter. Motor is stock except K & N filter and only tows a light weight Talon Cat-boat motor and trailer& fuel only 3000lbs. I have always run M1 5w-30 after break in can I go 20W-50? P.S.. this is the motor that sounds like a diesel for the first minute or two after start up. Also any new scoop on this motor noise. You all are the GREATEST!!!!! THnx
Jamie Bowman is offline
Old 09-30-2006 | 10:26 AM
  #822
Originally Posted by bcarpman
First of all, thanks for all the great info. It's taken me several weeks to go through all the posts in this thread, but I've learned a lot!!
There was a short discusion in the thread about oil thermostats. At one point Hydro posted a link to a combination cooler/thermostat, but at $500 it's a bit pricey.
Here's my issue: 454 being rebuilt from 330hp to around 430hp. I run in varried water temps, from 50F to 80F, and also varied running where I might never leave idle, or I might WOT it for 15 minutes.
I wouldn't mind upgrading the oil cooler, but then I worry about overcooling the oil such that it never comes up to temp, or really slow warmups.
Would an oil thermostat be a good idea? If so, does anyone have one they really like? Any more thoughts on running with oil that's too cold? Hydro stated that vapor not burning off at low temps was a myth. Any more thoughts on that?
How many of you run Oil temp guages? I've been surprised that I can't even find one to match my current Faria gauges.
thanks
Are you are still running the stock 330HP oil cooler? If you are replace it right away. That thing is so small it does hardly anthing. I replaced mine with a combo 3" EMI oil cooler. At minimum find a cooler from a magnum 454 or 502.
jeffswav is offline
Old 09-30-2006 | 11:55 AM
  #823
thanks
This one bypasses until 215*. I have one.
http://www.marine-performance-parts.com/
22-480 Canton Oil Temp Thermostat
Stingray69 is offline
Old 09-30-2006 | 03:06 PM
  #824
JB, personally if this was my vehicle I wouldn't run anything lighter than a 10w40. They (GM) says it's ok to run a 10w30 but not a 10W40. Yhant does not make sense if engine protection is your concern. Both of these viscosities have to meet the same specs at 0 degrees,(remember the W means winter, not weight). The only difference is that a 10w40 will offer more film strength at 210 than a 10w30. GM can't be concerned about cold weather pumpability, (they are both the same at 0 degrees), so they must be concerned about fuel milage.
A 10w40 showing a little more HP loss than a 10w30. (if you can measure it.)
I used to own a Mountaineer, the Mercury dealer said "do not run anything heavier than a 5w-30 or you will bolw the oil filter up. I ran 5w40 in the winter and 20w50 in the summer. Sold it with 110,000 miles on it and never blew up any oil filters. The heavier oil may also help with the start up noise as it will not drain off parts as fast and a heavier oil helps damp out the noise. Ken
minxguy is offline
Old 09-30-2006 | 07:26 PM
  #825
thnx minxguy. does anyone think I can go w/ M1 20w-50 V twin in the truck I listed above so I can get the extra zinc?
Old 10-01-2006 | 08:27 AM
  #826
I have a 68 Chevelle with a 385HP Fast Burn 350CI. The car sits
a lot and on startup with M1 10w-30 I could hear some piston slap.
I switched to M1 V-twin 20w-50 and the slap went away. Also
the engine runs cooler.
myturn is offline
Old 10-01-2006 | 07:46 PM
  #827
Hydrocruiser's Avatar
Arrow Re: Marine Lubrication
15W-50 M-1 would probably work too.
Synthetic oils pump a lot easier and you can safely go up a viscosity grade or 2.
I know guys with Vetters and Vipers using 15W-50.
Hydrocruiser is offline
Old 10-03-2006 | 11:24 AM
  #828
Jamie, what will help you more than the extra zinc is the heavier viscosity. Your first line of defense against engine wear is oil viscosity. Heavier oils leave a film which is harder to displace. It's when this oil film gets compromised (metal to metal) that reserve boundry additives (zinc and phosphus) come into play. Zinc is also an anti-oxident so lots of it contrubute to the long drain intervales of these types of lubes. Ken
minxguy is offline
Old 10-03-2006 | 11:31 AM
  #829
myturn, when you say the engine runs cooler,I am assuming oil temp and not water temp. If your oil is cooler, the 20w50 is not removing as much heat as the 10-30 you were running. Chances are your, piston crowns, exhaust valves, and cyl heads are all running slightly hotter. Remember a properly tuned engine runs at a given temp. Changing the oil does not change timing or jetting, so your combustion temps are the same regardless of the oil viscosity/type that you use. If your oil temps drop, the oil isn't absorbing the heat as well and bringing the heat to the pan. Hence, lower oil temps. Ken
minxguy is offline
Old 10-04-2006 | 12:57 AM
  #830
Water temp, though this is subjective. I need to replace the radiator and electric fans. The engine tends to overheat when running in traffic ans A/C on. Turning off the A/C and the engine runs at normal temp. The 20w-50 V twin seems to help this problem; hense, the subjective comment that the engine runs cooler.
myturn is offline
