Marine Lubrication >
Marine Lubrication
Marine Lubrication
Old 10-24-2006 | 11:24 AM
  #891
cuda's Avatar
Default Re: Marine Lubrication
Originally Posted by Hydrocruiser
After going around in circles on marine gear lube I don't think you can do better than Mobil-1 75w-90. The only thing it dosen't have is the word "marine" on the package.
I noticed that when I bought it. I figured if they would only stamp "Marine" on the package somewhere, they could move the decimal point in the price one place to the right.
cuda is offline
Old 10-24-2006 | 11:26 AM
  #892
cuda's Avatar
Originally Posted by Rebel_Heart
How is the Mobil 75w-90 different than the Amsoil products? Are you able to purchase the Mobil product in local stores?
I bought it at Auto Zone.
cuda is offline
Old 10-24-2006 | 11:28 AM
  #893
cuda's Avatar
bad seals typically are what cause premature drive failures.
That is a very true statement. I think for 99% of us, Merc dino lube is fine. Drives don't last long when they are lubricated with seawater.
cuda is offline
Old 10-24-2006 | 12:28 PM
  #894
Multigrade oils typically begin as base oils, such as 10W. Then viscosity-index modifiers (polymers) are added in an effort to stabilize the viscosity. This allows a 10W40 oil to flow like a 10W at cold temperatures and a 40W at higher temperatures.
The multigrade oils' viscosity modifiers are long-chain molecules that lessen the change of viscosity with temperature variance. In the past, the polymer additives (used to thicken the oil) were sometimes susceptible to viscosity loss. Permanent viscosity loss occurred when high shear forces (such as the relationship between the main bearings and the crankshaft) actually break the polymer molecules into less-effective smaller pieces. On a similar note, temporary viscosity loss also occurred when the polymer molecules aligned themselves in order to create a path of least resistance.
Fortunately, today's synthetic oil and additive packages have improved oil's shear-resistance. However, oils with the same rating from different manufacturers can exhibit different viscosity ratings in an operating engine, depending on the shear stability of their viscosity-modifying additives.
This means not all synthetic oils perform alike and the same goes for conventional oil too.
I guess i don't quite understand the theory on the changing oil weights. I just know for example, i run the 5W-30 in my truck in the winter because the 5w is thinner and will circulate the motor better on cold starts vs. say a 10w-30. But the 30 weight is a thicker weight, but when oil is hot, it isn't thicker, it's thin? Do you know what i mean?
cloudmaster_321 is offline
Old 10-24-2006 | 12:41 PM
  #895
Rage's Avatar
Where does Red Line Shock Proof Gear Lube 'Heavy' weight rate for the Bravo X drive versus the others mentioned?
Rage is offline
Old 10-24-2006 | 01:03 PM
  #896
Wobble's Avatar
SORE MEMBER
From their website
"Heavy ShockProof™
A unique lubricant containing a suspension of solid microscopic particles as an extreme pressure agent--unique solid dispersion which cushions gear teeth to help prevent tooth breakage and allows the use of lower viscosities. Recommended for heavily-loaded racing differentials and transmissions, Off Road racing and problem gearboxes. The viscosity characteristics allow the lubricant to resist throwoff and provide a film thickness similar to a 75W250 grade, while providing the same low fluid friction as an SAE 75W90. "
Probably the ultimate gearlube, I found it to be messy, hard to find and very slow to drain. Ended up switching to M-1 75/90 as it is readily available
Wobble is offline
Old 10-24-2006 | 02:14 PM
  #897
Rage's Avatar
Originally Posted by Wobble
From their website
"Heavy ShockProof™
Yes it is definately messy and slow to drain. I order it from OG Racing at 8.75$/qt at http://www.ogracing.com/eshop/home.asp?categ=69
If something just as good available that is not messy then I am interested.
Rage is offline
Old 10-24-2006 | 02:38 PM
  #898
Hydrocruiser's Avatar
Arrow Re: Marine Lubrication
15W50 M-1
The oil flows like a 15W when cold and has the same viscosity of a 50W when hot (100 degrees c). Your engine thinks it got an oil change to a "straight 50W" when it got hotter dude..
...AND since synthetics do not shear down due to their stronger base stocks.. you can use them in your go fast boat with confidence.. out to 50 hours too!
Simple.
Hydrocruiser is offline
Old 10-24-2006 | 02:44 PM
  #899
If somebody can develope a device to monitor the drives for water... with a very load ALARM attached to the dash board you could probably make a lot of $$.
Old 10-24-2006 | 02:56 PM
  #900
cuda's Avatar
Merc has already developed an alarm for water in the drive. First it sounds like a griding noise, then followed by a series of loud clunks.
cuda is offline
