454 MPI MAG cam?????? >
Old 07-18-2005 | 04:19 AM
9Hound
Cool 454 MPI MAG cam??????
Hay there, can anyone help with a cam choice. I have a 454 mpi mag, just bought some cmi headers, Topline 110cc heads, rolla rockers etc. Not sure what cam to run but big seems a good place to start. Will get arizona marine to do the CPU to 5300 rpm? Hoping for 500hp. Am i on the money or Not??. Thanks
Old 07-18-2005 | 10:56 AM
mjb
Default Re: 454 MPI MAG cam??????
there are many threads on this board that will go into depth on this subject. I just spent a year researching the same thing for my 502 mpi's. A couple of very important points- the correct cam is a direct reflection your head flow #'s...and bigger is not always better! Make sure you have acurate flow #'s and give them to your cam grinder. I used cam motion and they were great to work with. Also because your mpi is a speed/density setup, you must maintain a strong and stable vacume signal for it to work right. This means limiting your duration and overlap. That will also help with reversion althogh your cmi's are somewhat forgiving. use a cam with a 114 LSA and limit intake duration to no more than 230 at .050. I have a modified 502mpi with about 540 crankshaft HP. My specs are .590/.600- 228/233-114/110. That was matched to ported dart heads with good flow #'s. It idles great and no reversion with stainless marine exhaust. good luck-
mjb is offline
Old 07-19-2005 | 05:20 AM
9Hound
Thanks for the help. What about aluminum heads, yes or no. i have closed cooling so no salt in them. Apparently you can run more compression. Is this correct. Jas
mg503
Baja
14
04-03-2013 04:50 PM
mittens
6
06-06-2008 04:54 PM
cliff3466
1
03-09-2008 08:10 AM
alecsammy
7
11-10-2006 09:14 AM
MC-BOYS
7
07-11-2006 02:15 PM
