Gasoline Additives >
Gasoline Additives
Gasoline Additives
Old 07-27-2005 | 06:09 PM
Re: Gasoline Additives
Yes Sir re-Bob Hydro is on the money I've been using MMo for a while it's good stuff but it's a mystery. Hydro don't try to change my mind.
Badtoon is offline
Old 07-27-2005 | 08:53 PM
mwdill's Avatar
Default Re: Gasoline Additives
i have used the aimsoil one shot works good but not sure if you would want to use it in every tank,
i use seafoam more than anything, works great .
mwdill is offline
Old 07-27-2005 | 09:01 PM
Hydrocruiser's Avatar
Arrow Re: Gasoline Additives
the Mystery of MMO is that it actually does work!
Hydrocruiser is offline
Old 07-27-2005 | 09:04 PM
Originally Posted by Poorsche
I tried a jug of the Lucas additive because my boat hasn't gotten much use lately and it seemed like the lubrication and cleaning properties they CLAIMED were worth $6. I didn't picke any RPMS, top end or better hole shot (with boat)---but I did stay at a Holiday Inn Express.
Couldn't resist the smart-ass comment but I did talk to the Lucas race team in Sarasota and they were convincing and they were from Ocala.
The Lucas product is an oil "tackifier" ...it makes the oils stickier and gets it up into the lifters and other areas and helps hold it there. If you have worn parts like lifters and valves it can help quiet things down and instill better lubrication for a while.
If it is not working as such then you just need to be thinking freshing up that puppy maybe at the end of the season.
Old 07-28-2005 | 05:28 AM
Poorsche's Avatar
Hydro thanks for the feedback. I thought it wouldn't hurt to get some extra holdong power for lifters and valves since boat hasn't been getting as much use as I'd like. Everything is normal in engines given 700 hours but then I'm pretty anal about filters, oil, clean/fresh fuel. Just concerned about extended sitting and quasi-dry starts.
For the most part I feel like the fuel and oil additives are snake oil--and very profitable at that.
Poorsche is offline
berns29scarab
09-23-2014 10:47 AM
TYPHOON
General Racing Discussion
32
11-15-2008 01:58 PM
perform330
Mid Atlantic US
16
03-16-2008 07:02 PM
jafo
6
09-17-2007 09:19 AM
SS930
03-27-2004 02:41 PM
