Lost
Old 07-31-2005 | 10:15 PM
  #31
offthefront's Avatar
Default Re: Lost
Originally Posted by mopower
Yes , new heads. The engines are running fantastic. Start easy , no funny noises , no leaks , just this damned slip problem.
I did try one engine at a time today. left @3000 10 mph GPS. Right @ 3000 8 mph GPS and I could easily rev it higher with no additional speed.
you could rev the right with no more speed ? How bout the port ? ..... to me ....its gota be a) coupler b) hub c) clutches...
offthefront is offline
Old 08-01-2005 | 07:48 AM
  #32
mopower's Avatar
Toxic FORMULA
Default Re: Lost
Exactly.
Port engine will move the boat faster
a) changed the coupler
b)changed props 3 times including turning them in and out.(28" and 30" Bravos)
c)threw a spare drive on the right side.
d)examined the bottom of the boat.
e)removed speedo. pu since it's on that side.
I'm seriously giving thought to swapping engines and drives right to left. This will determine if it's mechanical or water flow to the prop , but man , it's prime season here now and i don't feel like going through all that...
mopower is offline
Old 08-01-2005 | 07:55 AM
  #33
cuda's Avatar
Default Re: Lost
Sure sounds like the coupler to me, only you should smell rubber burning if the coupler is slipping.
cuda is offline
Old 08-01-2005 | 10:13 AM
  #34
mopower's Avatar
Toxic FORMULA
Default Re: Lost
You're right Joe , I agree , but I just changed it the wednesday before July 4th for the same reason and it made no defference.at that point I did have some rubber in the bilge. I also asked a friend who is a Merc mechanic if he ever saw a "bad" new coupler and he said not in his 20 years experience. He DID concede he has see other new parts bad
mopower is offline
Old 08-01-2005 | 10:15 AM
  #35
Default Re: Lost
you need to talk to someone that knows the drives .....I am not sure if the clutches can slip .....or Swap Drives .... thats got to tell you something ...cpl hours of work .....
Old 08-01-2005 | 12:27 PM
  #36
mopower's Avatar
Toxic FORMULA
Default Re: Lost
I already put a spare drive on the right but before i get too crazy I am gonna swap drives left to right. I KNOW the left on is good
mopower is offline
Old 08-01-2005 | 06:58 PM
  #37
Payton's Avatar
Charter Member #927
Default Re: Lost
I know this is real simple, but You do have solid hubs in those props, right?
Did props get mixed up somehow? make sure they are what you think they are. I fought that for 3/4 of a season before I found that out once.
Payton is offline
Old 08-01-2005 | 09:50 PM
  #38
mopower's Avatar
Toxic FORMULA
Default Re: Lost
I have a set of 28" and 30" bravos with Flo Torq hubs. Tried both sets and new hubs and even swapped sides (tops in instead of out)
mopower is offline
BY U BOY
17
04-28-2008 09:52 PM
lightspeed
12-06-2006 07:23 PM
FX10
Superboat
10
11-29-2006 07:29 PM
dhlaw
11-06-2004 08:12 AM
CustomRigger101
12-06-2003 03:54 PM
