coil bad
Old 08-01-2005 | 08:14 AM
Default coil bad
what are the symptons of a bad coil on merc thunderbolt ignition?
sonic28 is offline
Old 08-01-2005 | 08:17 AM
cuda's Avatar
Default Re: coil bad
I've never in my life had a coil go bad, though I convinced myself that it was several times, then after the new coild didin't fix it, I had to find the real problem.
I just swapped out the module, rotor, and cap on my TBIV, and it fixed the problem. I'm pretty sure it was the module. I bought the parts from Bam Marine, and got them in one day.
cuda is offline
Old 08-01-2005 | 08:18 AM
GOODT's Avatar
rough running,after a little bit coil gets hot sometimes after the motor will shut off, no spark
GOODT is offline
Old 08-01-2005 | 08:30 AM
If in doubt, buy a $12 external resistor coil (GM) at any auto parts store. They work fine and are a lot cheaper than the Merc coil.
Gary Anderson is offline
Old 08-01-2005 | 09:04 AM
mr_velocity's Avatar
I lost my first coil last year. Motor started running really crappy then died. Pulled of the coil wire and was full of oil. Of all the spare parts I carry I didn't have a coil.
mr_velocity is offline
dukenrock
06-12-2007 05:45 PM
MnHowardCat
2
04-23-2006 09:13 PM
Waterfoul
04-21-2005 07:47 PM
24outlaw
2
08-13-2002 05:04 PM
